The X5 SAV Forum
Old 08-28-2012, 05:50 PM
robimicc robimicc is offline
Mein Auto: 2006 X5 4.4I
Trnsmission fail safe
Just bought 2006X5 4.4 with 65,000 miles and this morning the transmission fail safe, DSC, ABS, and Brake light came on after accelerating at a low speed. I pulled over to a parking lot and turned the car off, waited 2-3 minutes and started back up and all lights went off and the X5 runs great. What would cause this? Any thoughts from you guys?
Old 08-29-2012, 04:32 AM
Prometheus's Avatar
Prometheus Prometheus is offline
Prometheus
Mein Auto: X5 e53 3.0i 2006
The onboard computer sometimes produces false reports. However, when even a false warning is reported, it generally indicates that the computer has detected something wrong, and that a particular aspect of the cars operation will fail eventually. For instance, my 2006 3.0i produced the yellow engine warning light, which according to the owners manual, refers to "deterioration of exhaust emission values". I got home and turned the car off, had dinner, then returned to start the car an hour later. There was no warning light, and the car was fine for several days good driving, then low and behold, the engine warning light reappeared and remained emitted permanently. The dealer found the fault - a leaking air pipe that required replacing for $136AU. On two occasions recently, I have seen the red tyre pressure warning appear, which goes away after I press the tyre pressure calibration button located under the air conditioner system, but I am suspicious that the computer has detected a fault and that the warning will appear permanently emitted after the tyre pressure has failed completely.
These two examples highlight the general behaviour of the onboard computer, and in your case, the car may be absolutely fine, but if the light reappears intermittently or permanently, I would get your cars transmission checked out.
