H&R rear sway bar feedback? - Bimmerfest - BMW Forums
Old 01-13-2012, 11:27 AM
am_ver am_ver is offline
Mein Auto: '08 335i 'vert: soon
I have an H&R rear sway bar on my A6 and it make a tremendous improvement in the handling - therefore thinking of adding that to the X3 as well.
Wanted to get input from folks who have done this swap ... did it improve anything? Any issues from this setup?
Easy DIY - Instructions?!
Bay Area Realtor
2006 A6 3.2L Quattro
2008 335i convertible, 6sp MT, Montego Blue/Saddle, ZSP, Bluetooth, iDrive, PDC
2007 335i Coupe, 6sp MT, Montego Blue/Beige, ZPP, iDrive, PDC
2006, 325 Arctic, Beige, ZPP, iDrive, Xenon, Steptronic - Totalled
Old 02-10-2012, 06:21 PM
flynhawaiian flynhawaiian is offline
Mein Auto: BMW X3 3.0
Did you make a decision on this? I have a sports package and I'm thinking it might help the sway on the road. I see you're in SF, I find driving south bound on the I280 horrid from 19th to the I380. The stock sports suspension one is 18.5mm, and the H&R one is 23mm. The Front is 23.5mm so it should help balance out the car.
2004 BMW X3 3.0 and a 2006 Mini S to SMOKE Porsche 911s
Tiptronic Auto Trans
Premium Pkg, Sport Pkg, Navigation, Premium Sound (DSP), Privacy Glass, Homelink Mirror, Grom Audio USB, Euro Style Convex Side Mirrors, Hardwired V1 with Stealth One, Homelink Mirror, CG Locks!
Old 02-11-2012, 12:33 PM
shendrick shendrick is offline
Mein Auto: 08 M3, 05 e46 zhp, 07 X3
I would definitely want confirmation from a trusted source that this makles sense. H&R is a good company - but will the new bar actually improve the balance or simply promote more/less oversteer/understeer. This is where a trusted source who has done the swap and has pushed their X3 far enough to understand the difference is key. Last time I went downt his path (my pre-BMW years) - nothing but problems because the stiffer bars overstressed other components to the point fo failure. I would say leave it alone or experiment with different wheels and/or tires.
Old 02-11-2012, 01:38 PM
On my 2006 Mini Cooper S, then H&R bar was great. I'm just not sure how the X3 would stack up. She holds the road really well, but on bad road she just is all over the road. I would like to tighten that.
Old 02-11-2012, 11:37 PM
ioannis214 ioannis214 is offline
Mein Auto: X3, 2.0i, Manual, 10/06
If that's the case then a sway bar would make the problem worse, the car woud be easier to unsettle since force from one side would travel to the other side as well, wrecking the comfort. You wiuld probably be better off looking for different suspension alone set ups that soften the ride and offer more dampening. But then the car would be more unstable while cornering, but smoother on bad surfaces! You can't have everything, either corner handling abilities or comfort.... Especially in a car the size of the x3 and the inherent limitations that come from the height, weight 4wd etc it's even harder to make it drive that well.
Old 02-12-2012, 04:52 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Just remember, any changes you make will be responsible for any problems no matter how remotely connnected in the future.
Example: I had the technicians try to tell me that my car stereo installation was responsible for the latency issues in the AT problems.
I asked if I could have what he was smoking as that was one the lamest excuses I have ever heard.
However, stiffening up the suspension with sway bars will give you less body roll, but defintely make it "hop" on bad roads. I have never done that change on a X3, but have on other vehicles.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
Old 02-17-2012, 09:59 AM
It's not a hope, its rather the car is moving side to side. I think the road is cut up from a bad resurfacing job. I feel as though the rear tires are swaying. I could try to drive that part without the dsc engaged to see if that makes a difference.
On my mini I installed a new rear sway bar, and that solved the problem when driving through the oxnard fiasco. Gotta love that caldrons blunder...
Old 02-17-2012, 11:45 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
How many miles are on the X3? I had this swaying back and forth on bumpy roads and it went awa when I put on new shocks and springs.
Old 08-29-2012, 12:34 PM
34K miles are on the car. I have a front and rear H&R sway bar on the way. And I'm hoping that it will help cure some issues. All suspension components were looked at and inspected, including all bushings. Everything looks good under the car. Hopefully I'll get some good information for you once I get them installed.
