Old 08-29-2012, 03:24 PM
tamir15 tamir15 is offline
Mein Auto: 2006 750i E65
Can the ASK Mode button be programmed?
2006 750i E65
i have a problem with the Mode button on the ASK unit but i am not sure if it is an issue with the ASK unit (malfunction) or is it a programing issue.
initially when i pushed the mode button it wont do anything. it wont change the mode from AM to FM to CD etc.
i made some changes to my MMIGT module over the last few weeks (none related to the ASK unit) and now when i push the mode button the radio turns off.
any idea how to fix this issue?
Old 09-04-2012, 06:39 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
Assuming the changes were related to coding, you may have accidentially changed the below setting. I've always assumed this told the MMIGT that a facelifted ASK was installed with the MODE button. My 2005 is set to "not active".
HARDKEY_ASK
nicht_aktiv
2005 745i Individual
Old 09-06-2012, 04:21 PM
thanks rippjd. i checked it and it is set to aktiv.
not sure if it a code issue or the ASK hw issue?
