Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 08-29-2012, 05:36 PM
beastyz435is beastyz435is is offline
Mein Auto: Z4 35is
New wheels & tires
I am getting after market wheels for my 2011 Z4 35is and I am no expert on this field.
Will below sizes of tires & wheels pacakge fit to mine with any problem?
Front : 235/35zr 19
Rear : 265/30zr 19
I need your opinions.
Old 08-29-2012, 09:19 PM
onelsdplease onelsdplease is offline
Mein Auto: MINI
Those tire sizes are slightly wider and taller than original equipment but they would fit on OEM wheels. For a tire/wheel package you also need to meet parameters such as tire load and speed ratings, wheel widths, offsets, lug nut pattern, center bore, brake clearance, etc.
Old 08-30-2012, 09:52 AM
Mein Auto: Z4 35is
Thank you for the reply.
I'm not installing those tires on OEM wheels, but aftermarket wheels.
Shop told me that it will fit but they are so far away and I don't want to be end up with tires and wheels that would not fit to my car.
Old 08-30-2012, 11:56 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
They are the correct tyre wall height for the car as the same as the OEM 19" wheels, but they are wider>>> a few of the guys have fitted the wider tyre as you can read from recent posts!!!
Does my bum look good in this !
Old 08-30-2012, 01:17 PM
Mein Auto: MINI
Actually, for a 235/35-19 tire 35 is not the sidewall height. It is the profile which indicates the percentage of the section width that is equal to the sidewall height. A 235/35 is a wider and taller tire than a 225/35.
The OP wants to know if the proposed after-market wheels will fit but provides no information beyond diameter.
Tirerack.com is a decent place to learn about and/or buy tires and wheels that fit.
Old 08-30-2012, 02:22 PM
645/333's Avatar
Michael
Understood! I always believe that subject to the wheel diameter that a for example a 19" wheel with a 225/35/19 tyre was the same circumference as a 235/35/19 but not as wide ie 225 to the 235 as this aspect ratio also affects the speedo readings etc... without making it complicated!!!!
HTML code is Off
