Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-30-2012, 11:48 AM
skinchin13 skinchin13 is offline
SittinRock
Mein Auto: 1996 BMW 750il
New to e28s need help with starting issue
Hey everyone i am new to the e28s. I just bought an 1988 bmw 535is 5-speed about 3 days ago. The guy told me it had not been started since may when i bought it. It made the 2 hour journey from georgia back home. Well then i decided to change the oil and spark plugs and flush the coolant. Got all done and the car cranked over and died about 5 seconds later. So i rechecked all the spark plugs and went and bought a new wireset. Still did the same thing. So then i put a new fuel filter in it, and sprayed starting fluid in the intake. It fires up and runs but once you try to rev it the car bogs and stalls. I also tried changing out the relay for the fuel pump but that didnt help. So im guessing its either the fuel pump or injectors. But i dont know much about these cars so i need help. Also does anyone know a website i can get diagrams from, and diys.
Old 08-30-2012, 01:24 PM
catso's Avatar
catso catso is offline
catso
Your best bet is to buy the Bentley 5-Series E28 service manual. You can find used ones on Ebay, Amazon, etc.
![/I][/FONT]
Old 08-30-2012, 05:24 PM
south26 south26 is offline
Mein Auto: 535i 1989
you might have clogged up the fuel injectors with crappy gas that had been sitting in the gas tank. You can use mustang injectors in the 535i. You would have to look on mye28.com for the years. They are the same but cost a lot less.
Andy
Old 09-02-2012, 10:16 PM
SittinRock
Alright i will check around for some injectors after i do a pressure test
Old 09-07-2012, 05:42 PM
SittinRock
Would it still be the injectors if it runs and drives but if you beat on it just alittle bit it dies and the next day you can start it just fine. I got some junk yard injectors but i dont think they were to good. So i ordered some mustang ones off ebay(havent arrived yet). Also the car just got new fuel pumps and filter figured i would replace those too.
Old 09-08-2012, 05:09 AM
You can see if any of the injectors are clogged by getting the car running. Then start with the number 1 spark plug and pull it. If the idle changes the injector is doing something. If the idle does not change then the injector is clogged. Put the wire back on and do this for all 6. Make sure to wite down the number so that you remember. I had this problem with a 528e that ran like crap and had no power. It turned out 3 out of the 6 injectors were clogged. It ran much better with 3 other injectors.
Andy
Old 09-12-2012, 11:04 PM
BMWFatherFigure's Avatar
Old School
Take the injectors to a shop with a cleaning and test rig. Then you can be sure exactly what is wrong/right. Flush the fule lines and fuel rail while the injectors are out. Check the fuel filter again and do the pressure test.
Current:
E38 Parts Car
Previous:
Old 09-16-2012, 10:36 PM
SittinRock
Well i drained the fuel lines and fuel rail and put the new injectors in and it drives fine as long as the revs stay below 3500 rpm. then after that the car just dies still. Could it be my plug wires since i didnt go oem i went with the cheap ones $80.00 but the spark plugs are bosch platinum 4 prongs. And the car has no exhaust either so maybe its not getting enough back pressure at higher rpms. And all the other parts i put on are oem. Im just getting sick of messing with it.
Old 09-17-2012, 06:34 AM
catso's Avatar
catso
The Bosch 4 prongs may be a bad idea, stick with the plugs BMW recommends and put the exhaust system back on and see what you get.
![/I][/FONT]
Old 09-17-2012, 04:48 PM
SittinRock
Alright well i pulled the spark plugs out that i got(bosch) turns out that the #6 plug wasnt firing. So i checked the wires and the ones i bought from oreilly were peices of ****. I put the old wire set back on and she runs fine with those bosch plugs. Oh and i will try upload a video of the exhaust i put on this week if it turns out good. y-pipe converted to single 3in and straight back to a vibrant muffler with a 4 in tip. Thats the plan..
Old 09-17-2012, 08:34 PM
catso's Avatar
catso
OEM is always the best choice for BMW parts. Stay away chain auto parts stores cause it will only make the problem worse. There are alot of parts vendors that are Bimmerfest sponsors and most will give you a very good deal on quality parts.
![/I][/FONT]
Old 09-18-2012, 09:22 AM
SittinRock
Can you give me a list of sites please. and also what do you think of the bav auto wireset??
Old 09-18-2012, 10:42 AM
catso's Avatar
catso
Try this search engine: http://furiousmethod.com/ There's more than just the sponsors here but if you put in a part number you'll get lots of buying choices. And remember that you can always look up the part number you need on: www.RealOEM.com
![/I][/FONT]
Old 04-17-2013, 08:10 AM
BMW717 BMW717 is offline
Jonathan Houtz
Mein Auto: E-30
Their could be water in the gas tank- or vegtible oil, my friend had the same problem...he just got a new spark plugs
HTML code is Off
