Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 08-30-2012, 02:51 PM
plc001 plc001 is offline
Mein Auto: 2003 Z4 2.5I
Do our headlights have a clearcoat on them?
Mine looks like is peeling. Any suggestions?
Old 08-31-2012, 12:11 AM
TOGWT TOGWT is offline
Mein Auto: Jaguar XKE
Original equipment material (OEM) suppliers started to add ultra violet resistant (UV) coating to the surface of the lens in an attempt to reduce this condition and prolong the usable life of the lens. This protective coating is very thin (25 µ (microns or 1 Mil)
Removing oxidation or scratches from vehicle headlights or brake lights (also polycarbonate) also removes the OEM ultra violet protection, which prematurely decreases the durability of the lens. Surfaces that have yellowed are a sign that the ultra violet (UV) sacrificial coating has failed and must be resurfaced and recoated.
“Headlight Restoration” - http://www.autopia.org/forum/autopia...ml#post1506615
~ Providing unbiased opinions that Professionals and Enthusiasts Use and Trust ~ Blog-http://togwt1980.blogspot.com
Old 08-31-2012, 07:53 AM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Yes as stated above there is a coating and yours is starting to peel. My suggestion is to have a pro detailer wet sand and polish them back to clear. It's certainly something that you can do on your own if you are comfortable with it, but requires a buffer to do it correctly.
Then to keep them that way you should have a chemical based polish on hand like a paint cleaner and every few months polish them lightly and they will stay clear and clean. My 96 Camry lens are perfect.
Its Going To Cost How Much???????
Old 08-31-2012, 08:17 AM
Thanks all. I did some reading last night and I gave it a try this morning. Amazing what a wet sand and polish does!
Old 08-31-2012, 02:45 PM
Good job, not many are comfortable with wet sanding
