Old 11-06-2014, 06:20 PM
BMW62t BMW62t is offline
Past Sponsor
Mein Auto: 530i
SNJ BMW tech looking for work
South Jersey BMW certified technicians looking for work, specializing in diagnosis and repair of engine related issues. including internal engine repairs, cooling system overhauls, preventive maintenance(condition based services and flushes), etc.
OEM equipment will be used to diagnose and repair your vehicle to guarantee it will be repaired right the first time.
Common issues experienced with:
N62/tu
Valves guide seals and clogged secondary air ports
Including removal of cylinder heads, decarboning secondary air ports, replacing valve guide seals with updated seals, head gaskets, headbolts and all related seals that are needed during repairs.
Coolant transfer pipe
including replacement with upgraded internal coolant pipe, valley pan and performing cooling system flush
M54 engine damage caused by overheating
Including cylinder head removal.Cylinder heads will be sent to a local machine shop to be vacuum/pressure tested and be resurfaced as needed, timeserts will be installed into engine block. head gaskets, head bolts, necessary seals and cooling system components will be replaced.
N54/N55 carbon build up
Walnut blasting of intake valves and replacement of spark plugs (if needed) intake manifold gaskets and throttle body gasket will also be replaced.
S54 valve adjustments
valves will be checked with a feeler gauge and shims will be installed as needed. Oil change we be performed and all necessary gaskets will be replace.
N51/N52
Electric water pump and thermostat, eccentric valve position sensors, upgraded roller drag levers for lifter tap, oil filter profile seals, etc.
ZF transmissions
replacement of mechatronics sealing sleeve , valve body to transmission housing seals, plastic pan/filter replacement.
GM transmissions
Replacement of broken gear selector shaft
Only OEM parts will be used, unless specified.
Will install supplied aftermarket performance parts.
All repairs will be considered.
Please contact by phone or email with any questions or pricing.
Photos http://s1369.photobucket.com/user/bmw62t/library/ will update soon
Phone: (609) 470-0201( I work 8-5 if I do not answer please leave a message or send a text will return your call as soon as I can)
Email: bmwn62t@yahoo.com
Old 11-06-2014, 09:12 PM
Bimmer32's Avatar
Bimmer32 Bimmer32 is offline
Mein Auto: 2005 BMW 545i
I wish you were in Houston.
13' 750Li Glacier Silver, ARS & IAS. What's that?
Old 11-07-2014, 04:07 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
BMW62t has been helpful to folks on the forum, so consider giving him your business when you can!
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 11-07-2014, 04:12 AM
LivingProof LivingProof is offline
Mein Auto: 2007 530xi
Where in So. Jersey are you located?
Old 11-07-2014, 04:30 AM
Past Sponsor
Mein Auto: 530i
Millville
Old 11-07-2014, 11:25 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
M62 timing chain guide rails on an 02 X5 six hours away in chesapeake VA??
Just kidding.
I've just been too lazy to continue, I've got the front end all torn apart, but I have a full time job that keeps me there late and some Saturday's.
Old 11-09-2014, 06:08 PM
Past Sponsor
Mein Auto: 530i
Thank you
Old 11-10-2014, 04:07 AM
javvy javvy is offline
Mein Auto: 2007 530Xi
u will definitely get my business when the time comes...
Post it on craigslist as well, with this link to back your reputation...you will get better hits.
Good-luck...
Javvy
Old 11-10-2014, 04:32 AM
AW10to6 AW10to6 is offline
Mein Auto: 550i
I'm in Atlantic county, will def give you a call when I need work done.
Old 11-10-2014, 06:24 AM
Originally Posted by BMW62t View Post
Millville
Can you tell us a little more about when you are available? I drive through Millville frequently while commuting to the Jersey shore. Above you indicated that you have a full time day job, so, I presume weekends are when you can work on our cars. My issue is that it would be very difficult to drop off my car, I'd have to wait while you do the work.
Old 11-10-2014, 07:12 AM
Past Sponsor
Mein Auto: 530i
Could you please give me a call
Old 11-10-2014, 07:20 AM
Past Sponsor
Mein Auto: 530i
I do side jobs during the week when I'm out of work and the weekends
Old 11-13-2014, 01:45 PM
Past Sponsor
Mein Auto: 530i
Bump
Old 11-24-2014, 06:21 PM
Past Sponsor
Mein Auto: 530i
Up
Old 12-15-2014, 03:29 PM
Past Sponsor
Mein Auto: 530i
Bump
Old 02-02-2015, 09:05 AM
Past Sponsor
Mein Auto: 530i
Up
Old 03-14-2015, 08:57 AM
Past Sponsor
Mein Auto: 530i
Up
Old 03-14-2015, 11:08 AM
Mein Auto: 550i
You've got pm'd.
Old 04-11-2015, 12:14 PM
Past Sponsor
Mein Auto: 530i
Bump
Old 04-28-2015, 06:16 AM
Past Sponsor
Mein Auto: 530i
Bump
