Old 09-01-2012, 06:21 PM
Collie1 Collie1 is offline
Mein Auto: x5d
Remote not in ignition...car may not re-start
Has anyone had this prompt? A pix of a key w/ a slash thru it popped up when the car was started, and then the nav screen said that the remote was not in the iginition and the car may not re-start. I checked and the remote was in properly. As it was already running, I called service and they said to drop it off so I didn't get stranded if I turn it off and it won't re-start. If that happened it would have to be towed. They said that it was possibly the port where the remote goes in. The valet at BMW said he was able to turn it off and it restarted, and did not get the prompt????
Old 09-01-2012, 11:25 PM
ard ard is offline
Resident Curmudgeon
where was the second key fob when this happened?
Ive had this when the key that was oriignally used to start the car is removed...
Old 09-01-2012, 11:55 PM
Mein Auto: x5d
I have only used the same key fob since driving it off the lot January 2011. The other one was in a drawer in the hall chest.
Old 09-04-2012, 11:00 PM
sparrky sparrky is offline
Mein Auto: 535i - Xdrive
I got this 4-5 times in the last month and it went away. Each time the X5 shut off and restarted.
Brought the vehicle in to check it out and no issues found.
Old 09-04-2012, 11:01 PM
I have a 2013 X5 Premium.
Old 09-10-2012, 06:05 PM
Mein Auto: x5d
BMW service could not find (or reproduce) the problem, and said it was a fluke. It happened again two days ago in the garage. I turned it off, and it did restart.
Old 09-10-2012, 07:07 PM
ard ard is offline
Resident Curmudgeon
Next time it happens, pick up your cell phone and take a picturte of the icon, WITH YOUR OTHER HAND HOLDING UP THE FOB.
This warning occurs when the key is removed from the car while it is runng. SO, if it comes up when the fob is sitting in the car, there is an issue with:
1. FOB
2. Sensor
3. Software Bug
Tell the dealer you expect them to replace parts until it does not recurr.
A
Old 09-10-2012, 09:06 PM
ktono ktono is offline
Mein Auto: '13 X5 50i
Had this happen as well and service said that is was likely the battery being low in the fob. It has started every time so I have not been very concerned and only have a few months left on the lease so I am hoping this holds true. Good luck.
Old 09-11-2012, 05:40 PM
Mein Auto: x5d
I will take the phone pix...so service can see the icon, fob, and alert notice. I have always used the same key fob. Is that a no-no? Maybe it is the fob battery? Should I be rotating them?
Old 09-11-2012, 10:35 PM
ard ard is offline
Resident Curmudgeon
I'm too lazy to look, but I think the fob battery charges when you pop it into the dash slot. Do you occasionally?
Old 09-14-2012, 09:59 PM
AndyX5d AndyX5d is offline
Mein Auto: 2010 X5 3.5d
I've gotten this a few times I think it has to do with touching the fob after pushing the start button. I've never been able to remove the fob while running, and also never had the car not start.
Old 09-15-2012, 09:01 AM
ard ard is offline
Resident Curmudgeon
I've never tried to remove the FOB from the dash when started. I think most people with CA dont put it in the dash. Most. (ie not 'most in this thread, or most BF drivers...just a wild opinion...)
I've TOUCHED it many times (generally to move it out from under where I am goping to put my coffee) and never had a warning....
Anyway, understanding the logic of how CA works, and where CA has sensors, will be of interest .... I'm going to see if there is anything written on this, post up what I find
