Old 09-02-2012, 11:25 AM
7Figurez's Avatar
7Figurez 7Figurez is offline
Mein Auto: 2005 745I
Seat occupancy sensor disable Using NCS
If anyone is having the issue with the seat occupancy sensor, you can code this option out using NCS. Once you code the seat occupancy sensor out of the SSFA module you can clear the errors and the airbag light will remain off.
Change this in the SSFA or SSBF depending on the seat sensor that is failing:
FOR SSFA
BELEGUNGSERKENNEUNG_FA
sbe1
TO:
keine_sbe
FOR SSBF
BELEGUNGSERKENNEUNG_BF
oc3
To:
keine_sbe
Old 09-02-2012, 01:42 PM
johndade johndade is online now
Mein Auto: 2002 bmw 745li
Is one driver side and one passanger? Will restraint system have any issues in an accident or any other problems? I have a light for driver side on.
Sent from my Motorola Electrify using Bimmer App
Old 09-02-2012, 03:48 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
Nice job!
650i sport hud asanti af132
Old 09-02-2012, 03:57 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Great post!!! Move it to DIY section!
Old 12-02-2012, 10:44 PM
mjquake mjquake is offline
Mein Auto: 02 745i
i don't see any of these lines in either the SSBF or SSBA modules, do i have to add those lines or what. having this problem and would like to code it off
Old 12-03-2012, 06:07 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Will this work for a short? My rear seat headrest go up and down whenever they feel like it. Usually when its hot out.
HID Guide
LED Guide
Old 01-18-2013, 03:26 PM
badziewo badziewo is offline
Mein Auto: BMW 750i
Angry
Hi
Would you please help me with the seat occupancy sensor?
I did use NCSXEPERT to upload the SSBF module file.
Then I modify the file FROM: BELEGUNGSERKENNEUNG_BF oc3 To: BELEGUNGSERKENNEUNG_BF keine_sbe, Load the file back to SSBF module.
After that the light for Passenger Airbag went off for 20 sec and then the light come back. So then I reset the SSBF module with INPA. Went back to NCSEXPERT upload the SSBF module again and notice that the file is back to original, the keine_sbe is missing and the OC3 is back. I did it 2 more times with the same effect.
Can somebody help me with this?
2006 BMW 750i
GURTSTRAFFER_BF
aktiv
ZK_MIN_GURTSTRAFFER_BF
wert_01
ZK_MAX_GURTSTRAFFER_BF
wert_01
HALLSCH_EIN_GURT_SSBF
hall_ein_gurt_an
STROMGR_KS_HSCH_ZU_SSBF
wert_01
INDEXTAB_FC_SSBF
wert_01
STROMGR_AUF_HSCH_UB_SSBF
wert_01
CHECKCTRLTAB_SSBF
wert_01
ZK_MIN_AKTIVEKOPFST_BF
wert_01
ZK_MAX_AKTIVEKOPFST_BF
wert_01
TIMEOUT_ID_UEBERW_SSBF
wert_01
VERZOEGERUNG_SBE_SSBF
wert_01
LINKS_LENKER
linkslenker
PDC3_ERR_LIMIT_SAT
wert_01
GURTSCHLOSS_BF
aktiv
ALGOPARAM_SSBF_EAM
wert_10
AKTIVE_KOPFSTUETZE_BF
aktiv
oc3
ZK1_ZF_SSBF
vom_ss_nicht_beeinflusst
ZK2_ZF_SSBF
vom_ss_beeinflusst
Old 01-18-2013, 04:19 PM
DFEL750I's Avatar
DFEL750I DFEL750I is online now
Mein Auto: 750I
Originally Posted by badziewo View Post
Hi
2006 BMW 750i
GURTSTRAFFER_BF
aktiv
wert_01
wert_01
hall_ein_gurt_an
wert_01
INDEXTAB_FC_SSBF
wert_01
wert_01
CHECKCTRLTAB_SSBF
wert_01
wert_01
wert_01
wert_01
wert_01
LINKS_LENKER
linkslenker
PDC3_ERR_LIMIT_SAT
wert_01
GURTSCHLOSS_BF
aktiv
ALGOPARAM_SSBF_EAM
wert_10
aktiv
oc3
ZK1_ZF_SSBF
ZK2_ZF_SSBF
vom_ss_beeinflusst
Did you read the file again right after you wrote it to make sure it took the value?
Old 01-18-2013, 08:45 PM
Mein Auto: BMW 750i
Yes I did read it and was not there. But something did go in because the passenger light was off for 20 sec before I cleared errors with INPA. What I'm doing wrong?
Old 01-18-2013, 11:23 PM
DFEL750I's Avatar
Mein Auto: 750I
What you are saying does not make much sense. Maybe then module is reset when you are reading it or something. If you are writing to the module successfully there is no way for it to revert these options. Where in Toronto are you? Probably I can help you out and code it for you.
Old 01-18-2013, 11:34 PM
7Rage 7Rage is online now
Mein Auto: 2007 750Li
WTF?!?!
Old 06-07-2013, 04:26 PM
utkg utkg is offline
Mein Auto: 325i
DFEL750I
If you're in Toronto, you think I could get you to fix the srs light in my 325i (2006)? I'd pay you for your efforts. I'm in Vaughan. Let me know, thanks.
Old 06-10-2013, 12:56 PM
magicautocenter magicautocenter is offline
Mein Auto: 2003 745il
is there a way to reset air bag light and seatbelt message on by 745li without having to buy models.... both front airbag are deployed and passanger side seatbealt is locked. the rest of the airbags are good.. thanks
