Old 04-25-2013, 01:02 AM
HHBegg HHBegg is offline
Mein Auto: 318Ci Convertible 2003
Wheel Alignment Issue
Hey,
My two front wheels weren't perfectly aligned so I had my car laser tracked and the result was a smooth ride, for a few days. After a few days my front left seemed to be pointing left a small amount, while my right was pointing true, and I am now driving with the steering wheel turned ever so slightly.
As the alignment went only a few days after the tracking was done I assume there is another issue with the wheels.
Can anyone help? Has anyone had this problem before?
Old 04-25-2013, 01:12 AM
lgr122 lgr122 is online now
Mein Auto: BMW e46 1,9l M43
They didn't tighten everything properly?
I think you should go back and demand them redo it.
Or then again might be worn CABs... but even then they should have noticed and told you when doing alignment.
Old 04-25-2013, 01:17 AM
It happened so long ago that I can't go back and demanded a refund/refit. The only reason I didn't go back again straight away is because it cost me an arm and a leg in the first place.
Will have a look at the CABs and see what I find.
Old 04-25-2013, 01:26 AM
Oh i got impression that you just had alignment done few days ago.
Mine is bit off alignment also, but i'm planning to change few suspension parts still this spring, so no point to do alignment before it.
Old 04-25-2013, 07:08 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
If you have any worn suspension components: control arms, bushings, tie-rods, crowned shock towers... all can contribute.
Odd that you spent "an arm and a leg" on an alignment and chose not to go back within a couple of days for a re-check. I tend to demand perfection when I spend a lot of money on something.
Jeff R.
