Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Parting Out
Parting Out
Old 09-03-2012, 10:50 PM
laferrari7 laferrari7 is offline
Mein Auto: m5
M5/M6 E60/E63 S85 engine parting out
Parting out M5/M6 E60/E63 S85 engine with only 32k miles, let me know if you want pics of a specific part. Prices are negotiable.
Cylinder head cover + profile Gasket ZYL. 1-5.......Qt.....1..part # 11127891022.... $250.00
Cylinder head cover + profile Gasket ZYL. 6-10...............1..part # 11127891023.... $250.00
Control unit for ionic current.........................................2. .part # 13627834713.... $150.00
AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids..........1..part # 11367841073.....$1,100.00
AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids.........1..part # 11367841074.... $1,100.00
Vanos Oil line + connecting line.....................................1..part # 11367838670+11367834573....$150.00
Vanos High-pressure pump + GEAR wheel + Sprocket.........1..part # 11367841784.... $1,100.00
PRESSURE ACCUMULATOR ( bracket available )................1..part # 11367834553.... $200.00
TIMING CHAIN............................................. ...............1..part # 11317834163.... $60.00
Vanos gearbox, inlet............................................. .......2..part # 11367835343.... $450.00
Vanos gearbox, outlet............................................ ......2..part # 11367838395.... $450.00
Adjusting pulley with lever with Belt tensioner...................1..part # 11287839133+11287835417....$60.00
Connecting rod............................................... .............5..part # 11247838623.... $100.00
Connecting rod + piston and rings...................................3..part # 11257840922+11247838623....$130.00
set of piston rings............................................. ...........4................$40.00
Flywheel.......................................... ..........................1..part # 21212229955.... $500.00
Clutch............................................ ...........................1..part # 21212283648.... $300.00
Vibration damper............................................ .............1..part # 11237834097.... $300.00
INLET CAMSHAFT.......................................... ..............2..part # 11317835879.....$300.00
CAMSHAFT EXHAUST........................................... ........2..part # 11317836125.... $300.00
Camshaft sensor............................................ .............4..part # 13627834490.... $60.00
Oil pump + suction pipe.............................................. ..1..part # 11417837613.... $450.00
Oil sump pump.............................................. ..............2..part # 11417834496.... $200.00
Engine wiring harness........................................... .......1..part # 12517838569.... $450.00
Actuator Idle control device.........................................2.. part # 13417834495.... $400.00
Fuel INJECTION TUBE + 10 fuel injectors.........................1..part # 13537834120+13647834893....$450.00
Actuator.......................................... .........................2..part # 13627834494.....$650.00
Throttle Housing Assy + Hall sensor................................2..part # 13547834831+13627841705....$450.00
Thermostat housing + thermostat..................................1..par t # 11517839062+11537836155....$250.00
Connector ZYL. 1-5................................................. ....1..part # 11537835220.... $40.00
Connector ZYL. 6-10................................................ ...1..part # 11537834051.....$40.00
I also have many hoses and lines, let me know what u need and Ill check
ID:	340238   Click image for larger version
ID:	340239   Click image for larger version
ID:	340240   Click image for larger version
ID:	340241   Click image for larger version
Old 09-06-2012, 05:35 AM
michaelbmwm5 michaelbmwm5 is offline
Mein Auto: bmw m5
Looking for BMW M5/E60 Engine Rod
Hey,
I came across your ad and wanted to see if you have a BMW M5/E60 Engine Rod and/or bearings? Thanks a bunch.
Old 09-06-2012, 12:59 PM
Mein Auto: m5
Hi,
I have them. How many do you need ? all the rods comes with bearings. Let me know if you also need anything else.
Old 09-16-2012, 04:00 PM
SammyM SammyM is offline
Mein Auto: 2000 BMW 540i
Got any wheels that will fit a 2000 540i?
Old 10-07-2012, 12:18 AM
Mein Auto: m5
no sorry
Old 10-12-2012, 08:45 AM
allmotor_2000 allmotor_2000 is offline
Mein Auto: E60 M5 ESS VT2 RPI
Interested in several parts - I don't have PM so e-mail me.
allmotor.2000@gmail.com
Ionic control units specifically.
I am in LA.
Old 10-14-2012, 05:39 AM
sha3lan sha3lan is offline
Mein Auto: M5 E60
Do you still have the
Old 10-14-2012, 06:36 AM
Mein Auto: m5
yes i still have them
Old 10-14-2012, 11:42 AM
Mein Auto: M5 E60
send me an email to s.sha3lan@yahoo.com for further information.
Old 10-18-2012, 11:00 PM
Mein Auto: m5
bump
Old 10-26-2012, 09:11 AM
miroslavcvik miroslavcvik is offline
Mein Auto: BMW M6 year 2006
Smile Vanos pump 11367841784
Can you mail me ,i am interested in the High Pressure Vanos oil pump and can you do a little with the price.Thank you. My email is miroslav@concepts.nl
Old 01-15-2013, 07:18 PM
jstarr jstarr is offline
Mein Auto: e60 m5
Hi,
wondering if parts are still available. I am interested in the vans oil pump. (will these fit on an e60?)
4035619848
Old 01-28-2013, 08:30 PM
jenssteinhagen jenssteinhagen is offline
Mein Auto: 2006 M5
Clutch, Flywheel?
Hi,
Our 2006 M5 needs a new clutch and maybe flywheel at 118K miles. Do you still have these parts available? I am looking for the same parts that the new kits P/N 21212229955 and 21212283648 include. Photos of what you have would be great. Please email to 'jenssteinhagen at comcast dot net' or call me at two06-three31-nine989.
How much would shipping be to WA 98020?
Thanks,
Jens
Old 02-13-2013, 05:58 AM
Alex_skripalev Alex_skripalev is offline
Mein Auto: 2006 BMW M5
Do you still have Throttle actuator? Let me know alex_skripalev@hotmail.com
Old 03-21-2013, 04:47 PM
Juancarlozano Juancarlozano is offline
Mein Auto: BMW m6
Vanos
Hi
I need the following:
11367835343 / 11367838395
Please quote
And send contact info
Best regards
Juan Carlos Lozano
juancarlozano@yahoo.es
Old 03-21-2013, 04:50 PM
Mein Auto: BMW m6
M6
Hi
Mi name is Juan Carlos Lozano
I'm a big fan
Old 03-23-2013, 07:36 PM
Mein Auto: m5
update
I have the following parts left:
block and crankshaft
Cylinder heads
AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids (SOLD)
AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids (SOLD)
Vanos High-pressure pump + GEAR wheel + Sprocket (SOLD)
TIMING CHAIN
Connecting rod
set of piston Rings
Flywheel (SOLD)
Clutch (SOLD)
Vibration damper
INLET CAMSHAFT
CAMSHAFT EXHAUST
Camshaft sensor
Oil sump pump (SOLD)
Actuator Idle control device (SOLD)
Actuator (SOLD)
Throttle bodies Assembly + Hall sensor cyl 1-5
Throttle bodies Assembly + Hall sensor cyl 6-10
Connector ZYL. 1-5
Connector ZYL. 6-10
oil level sensor
I also have many hoses, vanos hoses and lines, let me know what u need and Ill check
Old 03-25-2013, 03:03 PM
Mein Auto: m5
all vanos gears sold, new list:
Flywheel (SOLD)
Clutch (SOLD)
2 Oil sump pumps (SOLD)
2 Actuators Idle control device (SOLD)
2 Actuators (SOLD)
Vanos gearbox, inlet (SOLD)
Vanos gearbox, outlet (SOLD)
Block
Crankshaft
2 Cylinder heads
2 Control unit for ionic current
TIMING CHAIN
Connecting rod
set of piston Rings
Vibration damper
2 INLET CAMSHAFT
2 CAMSHAFT EXHAUST
Camshaft sensor
Connector ZYL. 1-5
Connector ZYL. 6-10
oil level sensor
Old 03-29-2013, 09:27 AM
Mein Auto: m5
bump
Old 04-06-2013, 01:48 PM
Mein Auto: m5
bump
Old 04-19-2013, 12:58 AM
Mein Auto: m5
bump
Old 04-24-2013, 05:14 PM
Mein Auto: m5
bump
Old 05-10-2013, 09:25 PM
Mein Auto: m5
1 Control unit for ionic current SOLD, 1 left
Old 05-10-2013, 09:30 PM
Mein Auto: m5
prices are negotiable so make me an offer
