Old 09-04-2012, 05:29 AM
chintonmd chintonmd is offline
Mein Auto: 2008 535xi
Hacking the Safety Battery Terminal (how to trick the Safety Gateway Module)
I'm re-building a wrecked '08 535xi and needed to replace the battery terminal before having the new DME programmed. I'm not sure if it's neccessary but I know that the programming sequence will abort when it sees that the airbag fault can't be cleared. A wasted trip to the dealer ($$)
The Safety Gateway Module (SGM) looks for a certain resistance across the wires leading to the Safety Battery Terminal. A post on "1 Addicts" (or something like that) mentioned 2-4 ohms. I tried that and it worked. Actually I replaced my deployed cable with a $30 one for an older vehicle but it didn't work. It measured 0.1 ohms across the terminals. I plan to experiment and find what is the minimum resistance allowed by the SGM and add that to the circuit ot the cable. For now though I just have about 3 ohms connected across the plug without actually connecting it to the cable. The SGM is just fine with that. It saved me $250!
Old 10-23-2012, 02:38 PM
Keiperg813 Keiperg813 is offline
Mein Auto: Black 2007 328i
Can you show me what you had to do?
Old 10-24-2012, 09:45 AM
That's an 07 328i I'm rebuilding it got hit pretty hard on the drivers side. I still gotta get new doors for it but I'm waiting to see if it will straighten out first
