DSC Malfunction With Codes need help diagnosing
31K views 7 replies 5 participants last post by  young745i
#1 ·
Hi Everyone,
So the other day my car started popping up with a DSC malfunction on the iDrive. So I plugged in my laptop and pulled the codes (a crapload of them were stored), and I posted the PDF of those codes as before_clearing.pdf.
Then, I cleared the codes and one code seemed to stick and not go away:
5EE4
(under the DSC unit). This is posted as after_clearing.pdf.
Does anyone know what the issue might be? Thanks everyone in advance for your help, I really appreciate it.
#2 ·
If the Functional Job for reading error memory out of all modules is not giving a written description of what the 5EE4 fault means, then go to your DSC module and read the fault there.
Posting the result would likely lead to others giving their thoughts...
#4 ·
I talked to a few independent mechanics, and it looks like the issue is with my ABS pump because of the 5EE4 that keeps coming up. I just sent it into module masters to repair it, will let you all know in 1 week if that fixed the issue.
It kept saying something was wrong with the DSC/ABS in the iDrive.
Here is what 5ee4 shows from my BMW code sheet:
0x03435EE4 5EE4 Hydraulic unit, pressure sensor: internal
Thanks all. Let's see how it goes...
#5 ·
Update for everyone, reinstalled the ABS module after module masters fixed it. Reset the codes. The dsc light stayed on for a few minutes, but after I drove the car around for 5min all of the codes went away. Success! Car is now fixed, thanks everybody. Only $350 instead of $1300 from the dealership
