Old 09-05-2012, 08:50 AM
leannaluv leannaluv is offline
Mein Auto: 04 BMW X3
Question Flat tire indicator light
Ive had this warning light come on in the past, I ran over a nail, got the tire repaired, followed instructions per manual and the light went off.
However, I just had 4 new tires put on and the light is on? Doesnt make sense. When my tires were trashed and tread was obviously uneven, light didnt come on, I have 4 newbies and its on? Go figure.
Old 09-05-2012, 08:56 AM
vince217 vince217 is offline
Mein Auto: 2011 R56 Non-S
try resetting the light and see if it goes away.
2005 E83 X3 2.5
2010 Acura MDX Tech
Old 09-05-2012, 11:31 AM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
The Owner's Manual recommends resetting the tire pressure monitoring system (TPMS) every time any tire pressure is adjusted -- which it obviously was when you put on new tires. Resetting the system establishes the new 'baseline' tire pressure values for the TPMS -- the values you want maintained. If the actual tire pressures vary too far from these values, the system alerts you to the discrepancy.
Obviously, one or more of the current tire pressures (inflated when the new tires were installed) are beyond the thresholds you'd previously set. Resetting the system to use your current tire pressures as the 'baseline' values should solve the problem.
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 09-05-2012, 05:59 PM
535MSport's Avatar
535MSport 535MSport is offline
Mein Auto: 528
reset?
I can find nothing in the manual of our new 2013 about resetting the monitor. Pointers?
Old 09-05-2012, 07:53 PM
x3brian x3brian is offline
Mein Auto: X3
Leanna--
If my memory is right right you have an 04 or 05. That model does not have direct tpms like the 06 and newer. My bet is that it hasn't yet been reset. Just do a quick check of the tires to make sure you don't have any nails and if you have a pressure gauge make sure you have at least 33psi in the tires. Next time by the tire shop have them reset it.
F10ster-
If my memory is right the tpms setting in the f25 and f10 is in the Idrive menu. Hit menu and navigate to vehicle settings. You should see a vehicle info option that pulls a picture of your car up. The second or third option down should be tpms reset.
