Old 09-05-2012, 09:02 AM
chriskansas2000 chriskansas2000 is offline
Mein Auto: 2000 BMW 528i
New Owner: 528i suggestions?
I'm new to this forum. Just bought my first BMW. It's a 2000 BMW 528i with a 105,000 miles.
The guy who sold it to me has changed: cam sensor, radiator, new brakes all the way around, water pump and belts. I don't know what else I should be concerned about maintenance wise.
Also, was wondering if anyone knew what could help to get a little more power. Will intake, exhaust, chip or what would help? Do any 5 series parts fit on the 528. Was thinking about putting a 540 or m5 bumper and tail light. and any wheels suggestions?
Chris C.
Old 09-05-2012, 09:15 AM
cn90 cn90 is offline
Forget the chips.
Search forum for DIYs on different things.
Cooling overhaul is the priority, you need to get down to the nitty gritty details such as the bleeder screws.
Old 09-05-2012, 09:26 AM
OntheRock OntheRock is offline
Mein Auto: 530i
Hi
and welcome! there are a host of very useful strings contained in this forum and you'll find that after taking the time to research and read ...a great many of your questions can be answered.
As one of the frequent posters to this site councils we "newbies", we should search, read and then ask (or words to that effect). I have found that to be sound advice and try to put it in practice.
Good luck!
Old 09-05-2012, 09:35 AM
Fudman's Avatar
Fudman Fudman is offline
Before you attempt to improve the power, you need to restore the original power and torque. That said, these are your priorities:
1. Replace anything within the cooling system that hasn't already been replaced, especially the expansion tank. This will restore the reliability of the engine. Do this first as a cooling failure can kill your engine.
2. Replace your Vanos seals. This will restore the timing of the engine. You will be amazed at the improvement in torque. Search Beisan + Vanos for more info. About $100 in parts but 4-6 hrs of DIY labor.
3. Replace your pre-cat O2 sensors. This can improve your gas mileage and the smoothness of your engine. $100 and a 30 min DIY.
4. Consider refreshing your front suspension system. Struts, contraol & thrust arms, tie rods and sway bar links. About $1200 in parts + labor but will transform your ride and handling to like near-new.
5. Save at least $1K for the unexpected (CCV, DISA, SAP, FSU, etc.) issues. After that, then waste your money on bling.
Remember to use only OEM parts unless alternatives are advised. Good luck!
Old 09-05-2012, 10:09 AM
Previous owner says expansion tank, radiator, water pump, hoses, thermostat and belts have been changed so what that be considered a complete overhaul?
Thanks for the info.
Old 09-05-2012, 10:16 AM
Fudman's Avatar
You're pretty much good to go on cooling. The only other things to consider are your tensoners and idler pulleys. Focus on the other things now.
Old 09-05-2012, 10:24 AM
Ok, cool. Do know where I could find the new style vanos seals?
Old 09-05-2012, 10:36 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
http://www.beisansystems.com/
Old 09-05-2012, 11:12 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
if you want different wheels just make sure you buy the correct fitment for an e39, bore size 74.1.
headlights and tail lights check out umnitza
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 09-05-2012, 03:56 PM
IndiansFan's Avatar
IndiansFan IndiansFan is offline
Mein Auto: '99 528iA
chriskansas: If your location is Kansas, or anywhere where you get measurable snowfall accumulation, you might consider waiting till next spring for new wheels and tires. Put a set of four snow tires on your existing basketweave wheels for the winter.
Either write something worth reading or do something worth writing.
Benjamin Franklin
2004 X3 2.5 TITANIUM SILVER/Grey - Sport/Premium Package
2001 530iA STEEL BLUE/Sand - Sport/Premium/Cold Package
1999 528iA JET BLACK/Black - Sport/Premium/Heated Seats
1982 Fiat 2000 Spider - BLUE METALLIC/Blue
1999 528iT CASHMERE BEIGE/Sand - Sport/Premium Package - 5 speed SOLD
1989 535i SALMON SILVER/Black SOLD
Old 09-05-2012, 05:04 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
The op already has good advice so I'll just answer the maintenance question by pointing to this:
- BMW_realistic_maintenance_schedule_2009.pdf
And, the power question by pointing here:
- CAI 101 should I do it or not (1) and which is better, stock or aftermarket cold air intake (1) (2) & a home-made CAI (1) & the general consensus on the effectiveness of an aftermarket CAI versus the stock BMW CAI (1) (2) (3) (4) (5) & how to reduce the risk of hydro lock (1) (2) & what about a K&N oiled air filter over the stock air filter (1) & a forced induction group buy (1) and adding nitrous oxide to your E39 (1) & links to suppliers to improve performance of your E39 (1)
Old 09-06-2012, 08:43 PM
thanks everyone for the info. buying some vanos seals tomorrow.
