E34 (1989 - 1995)
Old 09-05-2012, 05:14 PM
calikid1959 calikid1959 is offline
Mein Auto: 1995 525i
1995 525i tail light problems
help !!! my 95 525i tail lights on the trunk lid won't come on. i have power to the tail lights,changed the bulb multiple times, jus don't know where to go from here? ae the tail lighs on the tunk lid supposed to be on with the headlights or are they just for backup lights which by the way don't work but suspect backup switch any advise
Old 09-05-2012, 11:26 PM
Mein Auto: 1989 525i M20B25
I believe they are only for the backup lights unless you have rear fogs? Or maybe there are two sockets...
I'm probably wrong, have somebody else run out and check.
Old 09-05-2012, 11:49 PM
BMWFatherFigure's Avatar
Old School
White or red lenses?
Old 09-06-2012, 02:17 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
there are no taillights on the rear lid, only reverse lights, and, if equipped, the rear foglights. there are only two taillights on an E34 which are on the corner clusters
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-08-2012, 09:02 PM
My525iT My525iT is offline
Mein Auto: 92 525iT Wagon M50
You need to check all of your light bulbs. It only takes one incorrect bulb on the circuit to mess up some of the other lights (both front and rear).
It happened to me. I had an incorrect headlight bulb and it caused my rear blinkers/tail lights to react strangely. I believe the car prefers dual filaments. Good luck.
Old 09-09-2012, 12:25 AM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
check for damaged wires at trunk hinge. for some reason the get broken there. Also wrong wattage bulbs can melt the scokets to the point they dont work any more. I think its just backup lts on the trunk lid and red reflectors.
Old 09-09-2012, 01:53 AM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
Unless you have rear fog lights, the lights under the reversing ones will not light up no matter what. This is because there is no wiring for them. Unless you know that your car was originally ordered with rear fogs I would remove the bulbs and save them for anything else that will eventually burn out.
