Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 09-05-2012, 07:08 PM
Mr. Jaws Mr. Jaws is offline
Brut in a Suit
Mein Auto: 1981 BMW 633CSi 5Spd
instrument panel lights
Good evening gents...I need to find out how to change my light bulbs that light up my speedo and tach panel. I have an 81 633CSi. thanks for any and all advice in advanced...
Old 09-08-2012, 02:31 PM
BMWFatherFigure's Avatar
Old School
Steering wheel off. Screws in upper underside of cluster (2 Ithink). Wiggle cluster towards rear of vehicle and un plug wires - make notes if some single wires of where they go. Unclip and change globes. Reverse order of removal. Maybe disconnect neg ternimal of battery first - depends on you.
Old 09-11-2012, 07:32 PM
Brut in a Suit
Thank you fine sir.....ill get right on it...
Old 09-12-2012, 09:49 PM
Brut in a Suit
come to find out..on the 81 the plexi glass cover just pops out with a screw driver....i also got the middle panel out.....now i need to pull the cluster out...a whole nother ball game...the left side seems to be screwed in yet i cant find where its still attached...ant advice..
Old 09-12-2012, 11:15 PM
Old School
Havnt played with one of these for ages. Screws holding the unit(s) are top corners usually. Possible a bit of the dash skin is masking seeing the screw. Dont force the instrument cluster - the plastic will be brittle and may snap. Then it is super glue etc..
Current:
Previous:
HTML code is Off
