BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
Just PM me. I'll hook your car up.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#27
So, so far we a 528i and a 520D where both had to be set to Aktiv for it to work. Not seeing the reason here yet.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 09-09-2012 at 07:39 AM. |
#28
![]() Did you notice any changes? |
#29
It actually feels quicker off the line, but I dismissed it as wishful thinking. I don't know for sure. It does feel different though.
#30
My 535i has no sport package or M sport. I had to switch BOTH
Sportschalter_alt = aktiv Sportschalter = aktiv for it to work. I tried just Sportschalter_alt = aktiv first and no luck, when I switched BOTH of them it worked perfectly. Thanks again for the Post Shawn !!
2012 535i, April build, Space Grey, Oyster Interior, 19" M sport rims/tires, premium pkg, premium sound, side/top cameras, heated seats, comfort access, ceramic controls, OEM spoiler, painted front reflectors, 35% tint, rear Fog lights, coded to my liking. |
#31
Sportschalter_alt = aktiv Sportschalter = aktiv I get S1-S7. |
#32
I had to change both to show S1-S7
Boca Raton, FL, USA |
#33
I'm sill trying to figure out how to get the S1-S7 to display when I put the tranny into sport mode via the adaptive driving toggle. If anyone figures that one out please let me know.
The DEC Sport Mode is Suspension and Steering, with no bearing on the transmission shift points I don't think.
#35
Drivetrain is effected (if selected). In my case the tranny absolutely goes into sport (no 8th gear) mode since I have drivetrain selected to be controlled. Whether I pop the shifter to the left or toggle the the switch to sport mode, the tranny reacts the same (of course I have to either move the shifter or tap the paddles if I want to force a gear change but other than that the tranny reacts the exact same.
#37
I'm going to do a test run later tonight where I'll note the gear changes, etc. when I put the tranny in sport via the toggle and via the shifter. I'm ivory pure (99.44%) sure the tranny is behaving the same in both those modes. If it was not then there would need to be three distinct operating modes (besides manual shifting M1-M7): normal; sport (induced by moving the shifter to the left); and sport (induced via the adaptive drive toggle).
#39
I commented earlier that it was easy to make the change but unfortunately I was not able to test it at the time (wife's car). When I did, I still only got DS. I then tried change both items, and still no change to S1-S7. I have a 2013 X3 28i with no M-Sport, SAV, or paddle shifters (again, wife's car).
#40
#41
I did my ride tonight and I gotta tell ya, there is ) difference in the behavior of the tranny between popping the shifter to the left ot togglinh to sport mode using the adaptive drive switch (with drivetrain turned on in the settings). The transmission acts identically in both settings. So my question is if it goes into the same mode why doesn't BMW display the S1-S7 when we are in "sport" mode (again, providing you have drivetrain effected in the settings)? BTW, if I slide the shifter to the left when I'm already in "sport" mode nothing changes (except the ability to manually change the gears).
#43
@shawn
mayby try change "Sportschalter = aktiv", mayby then you will have some changes in shifting, not only s1-s7 on display. |
#44
I then put it back in back in regular D Mode, and moved the DEC Switch to Sport, and the transmission did the same exact thing. No difference. They are the same thing. I guess I just never noticed before because I always drive in DS Mode, so when I activate DEC Sport, there is no change with the transmission since it is already in Sport Mode. Then I read this, which confirms it: Driving Experience Control (Sport): http://www.bmw.com/com/en/newvehicle...trol.html#more A touch of the Driving Experience Control next to the gearshift lever changes the level of driving pleasure from COMFORT to SPORT: the engine responds more spontaneously to the accelerator and the eight-speed transmission Steptronic lets the engine rev high before quickly changing up a gear. At the same time the steering and chassis tighten. So, DEC Sport is indeed adjusting the Throttle, Transmission, Steering, and Chassis. I am with you now Sharbotcom. The transmission display ought to show DS when in the DEC Sport Mode.
#45
Thanks Shawn. I appreciate the effort to follow up on my understanding. Now my question goes back to: "Why doesn't BMW have the S1-S7 displayed when you enter in sport mode (transmission) when you do it via the toggle?" I'll keep looking for a coding answer but I suspect there may be triggered by a relay on the shifter instead of the tranny itself.
I don't understand, do we need a special tool to do the coding? Or we can just use a software installed on the computer to do it?
What is needed actually? Thanks |
#47
To Code, you need E-Sys coding application, PSdZdata coding data files, and an ENET Cable.
#48
Hi Shawn,
Thank you so much for the quick reply. I really appreciate it. Anyway, do you know where i can buy the enet cables? I would love to buy them for me to try out coding myself. Also, do you know where can i download the e sys application? Thanks again. |
#49
PM sent.
#50
Thanks a lot Shawn for the information.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
