Old 01-20-2013, 05:43 PM
vesper vesper is offline
Mein Auto: BMW M6
Originally Posted by shawnsheridan View Post
PM sent.
Anyway Shawn, from another thread i saw that you did change the sport auto shifter. Does changing the shifter alone affect the way how the transmission shifts? Or is it just the s1 - s7 coding that affect the gear changes?
I am really interested on doing the paddle shift retrofit as well. And do you have any idea on how doable it is to do that? Is it as simple as running cables from the shifter to the paddles on the steering or is it something much more complicated involved?
Ps: Sat shifters and sport steering wih paddles are not my concern anymore.
Old 02-18-2013, 06:44 AM
Donghoi, Kim Donghoi, Kim is offline
Mein Auto: MINI R56S LCI, F10 520D
Actually, that code was discovered by my Korean brother, mongsiri. All credit goes to him.
D1-D8 to go along with S1-S7 would be nice, but I did not see anything in EGS for that. Although since my car seldom operates in that girly mode, I admittedly did not give searching for that code its due diligence.
Hello Shawn,
Your posts on Bimmerfest.com and Bwmcoding.com are always very helpfule to me..
For example, http://www.bmwcoding.com/showthread....h-to-icm/page2
I'm the member of BMW F serise club in Korea and I firstly introduced e-sys coding to F club.
I found this this value for S1~8 display on 20. July, 2011
http://cafe.naver.com/5series/67991 (Sorry, You need registration to read the posting in Korea)
I think, 'mongsiri' is one of F club member.
Thank you again!!
Old 02-18-2013, 06:54 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by Donghoi, Kim View Post
Hello Shawn,
Thank you again!!
Well tell mongsiri I said hello. I haven't heard anything from him in a while.
And if you get to Okku-Silver Town, give all the girls my best.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 02-21-2013, 05:04 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Only Sportschalter_alt needed on my 520d 4/2011 to make it work. I don't have sports trans nor M options..cool find.
F10 520d born 11.04.2011 Deep Sea Blue
205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1
Old 03-26-2013, 10:20 PM
Alex68 Alex68 is offline
Mein Auto: BMW 328i
Well, that is rather interesting. On my M-Sport, Sportschalter by default was nicht_aktiv, and when I changed it to aktiv, it did nothing. I changed it back to nicht_akt, and then changed Sportschalter_alt to aktiv, and got S1-S7. So, Sportschalter by itself did nothing, and Sportschalter_alt by itself gave me S1-S7.
I thought maybe then based on what you experienced that Sportschalter got it to the Sport / M-Sport equivalent, then Sportschalter_alt brought it to SAT. The problem with that though is I would have expected Sportschalter to default to aktiv on cars with Sport / M-Sport, but that isn't the case. So, this doesn't make much sense.
We need to test a few more non Sport Cars and Sport / M-Sport cars, and see if this behavior is at least consistent, where both are needed for non Sport, and only Sportschalter_alt is needed for Sport / M-Sport cars.
I changed only one settings on my F30 328i.
I have only automatic 205 in gearbox.
EGS / 3000 Applikation
Sportschalter_alt = nicht_aktiv
Sportschalter = aktiv
Now it (S1-S7) works, but I do not know whether it's right or not?
Old 03-26-2013, 10:31 PM
If it is working, it is right. Some have to change only one, and other have to change both.
- BMWCCA #446923
- flick
Old 03-26-2013, 11:24 PM
Mein Auto: BMW 328i
Thanks a lot Shawn
Old 04-24-2013, 10:41 AM
Nison Nison is offline
Mein Auto: 2011 535i xdrive
code an 2013 535i today, had to change both Sportschalter_alt and Sportschalter to aktiv / Werte=01
Old 04-24-2013, 02:38 PM
JamRWS6 JamRWS6 is offline
Mein Auto: 2012 BMW 535i MSport
I checked my '12 M sport and both of these are enabled by default. I do have the SAT option w/ the paddle shifters. Not sure if that helps w/ whether to activate both or not.
Old 04-28-2013, 04:03 PM
maxpnc maxpnc is offline
Mein Auto: F30 328xi
To anyone who is interested in coding this on a F30 (I have a sport line non M), the result sort of changes how sports mode is entered and how it behaves; I have modified as
or both active and I could not tell any difference, with just sportschalter active you will be able to see S1-7. Before the modification, with both not active, DS is displayed in sports mode and if you tab the control lever left or return it to normal position, sports mode or comfortable mode is selected automatically. After the coding, with either with just Sportschalter active or both active, taping the lever to the left or normal position does not automatically select sport mode or comfort mode, instead, it will active the S1-7 display and put transmission (and transmission only) in sports mode. And after you manually select the mode through buttons to the left of the lever, the rest of the car goes into sport mode. (steering, accelerator etc. ) Please correct me if I am wrong.
