Old 10-04-2012, 01:28 PM
voip-ninja's Avatar
voip-ninja voip-ninja is offline
Swedish Murder Machine
Mein Auto: 340i x-drive
Originally Posted by Michael Schott View Post
I hope this has fixed the problem permanently. Sounds like a comprehensive change. Your home contacts are not stored with the car by the way. They come from the phone via bluetooth. To test, drive your car without the phone. No contacts.
In the car navigation you can store addresses from your contact list into the navigation menu. That's the only way I've been able to navigate to a contact address.
It sounds as though they replaced the Combox or whatever the control unit is, but the Bluetooth module was kept in place, which should be fine.
** Removed - Tim330i **
Old 10-04-2012, 02:52 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Originally Posted by itswendy View Post
I just got the car back, eight days later. The receipt says, in summary: CIC headunit shorted (1381) FC s010A media oriented system transport ring break stored, performed test plan etc., test plan stated to replace cic head unit diagcode D6510_HU00000_90_001 etc. Created PUMA case, explained etc. PUMA said to create a TX XASE, created TC Case, replaced CIC headunit, performed programming/encoding with enabling codes, after prog concluding work notes stated to interrogate fault memory, interrogated fault memory and cleared faults. Verified correct. etc.
All I was told was that the iDrive was replaced. I noticed my Sirius pre-sets were gone, my map points were gone, but my phone Bluetooth records were still paird and in the car. We'll see how it goes.
Presets are stored in the CIC so those are gone once the CIC is gone. Phone contacts are uploaded once to the Combox via Bluetooth from your phone and then saved in the CIC. Any subsequent pairing will look to changes in the phonebook and upload those as well.
Old 10-04-2012, 04:20 PM
itswendy itswendy is offline
itswendy
Mein Auto: 2013 BMW 335i
Thank you, Michael. thegandalf and everyone!
Old 10-04-2012, 04:27 PM
itswendy
I see, thank you, voip-ninja!
Technic - I did not re-pair the iPhone - it still showed "paired" on the phone....
Sorry, I am not that technical
Old 10-04-2012, 07:23 PM
rdle_F30 rdle_F30 is offline
Driving for fun again. .
Mein Auto: 2013 335i SportLine
From your description is sounds like the iDrive was replaced. Hope it's fixed and problems are gone.
Old 10-05-2012, 04:30 AM
Technic's Avatar
Mein Auto: 2017 M3
Correct... the Combox was not replaced. The Combox is a separate module from the CIC (replaced).
Old 10-05-2012, 05:38 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Thank you. I am used to my E90 without navigation. I misspoke.
Old 06-25-2013, 03:40 PM
tdub408 tdub408 is offline
Mein Auto: 2012 328i
Angry iDrive on/off issues
Looks like BMW hasn't yet fixed this issue. I recently bought a 2012 328i with 10k miles on it and the iDrive system shuts down, then boots up, and then cycles off and on continuously. Sometimes it works fine. Disappointing since it's a factory demo that's never been plated, and I've only had it for a week. Based on some of the older posts that I've read, seems like this problem has existed for some time. You'd think BMW would have this kink worked out by now. Already scheduled an appointment to have it "diagnosed".
2013 idrive
