Old 09-09-2012, 07:17 AM
CaptainTrap's Avatar
CaptainTrap CaptainTrap is offline
a man made of men like me
Mein Auto: 2001 330i 5MT ZSP
Car is off, Key is out, Dash is on...
So this morning my roommate woke me up saying my windshield wipers were on. I thought he was messing with me cus i had the key sitting on my dresser right in front of me. I went out and sure enough they were wiping away and the dash was on as well. I turned the wipers off and rolled the windows down all with the key out.
It did rain a little in my car last night as i had the windows cracked when it started.
Is my ignition switch shot or what?
2001 330i ZSP 5MT H&R Sport Cup Kit 18" VMR v710 18x8.5
BMW CCA #: 399644
Old 09-09-2012, 07:39 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
May very be the ignition switch but I would dDisable the battery first for a few minutes then reconnect and see what happens. You can also check the battery voltage without load because I think all you need is a new battery!
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 09-09-2012, 08:53 AM
Battery volt while off is 12.14v
While on it was 13.98v
BMW CCA #: 399644
Old 09-09-2012, 09:29 AM
mawana's Avatar
Mein Auto: e46 ZHP
You numbers are lower than expected but not bad! Have you tried disconnecting the battery entirely for about 10mins and then starting your car? I would get the battery recharged at AZ, takes about an hour.
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 09-09-2012, 12:48 PM
I disconnected the battery for twenty minutes and reconnected it- it did not fix the problem. I am driving the car and noticed that my speedometer and fuel efficiency dials are not working as well as my dash computer selector on my blinker indicator level.
BMW CCA #: 399644
Old 09-09-2012, 02:46 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
How old is your battery? If it is more than 4 years old, you may want to replace it. This often fixes mysterious electrical gremlins; but it is not a guaranteed solution.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 09-09-2012, 04:07 PM
Battery is less than 2 years old but it is a Walmart battery. The rain has to have something to do with this.
I just checked all three central locking fuses and all three instrument cluster fuses and all are fine.
BMW CCA #: 399644
Old 09-10-2012, 06:36 AM
I left the battery unplugged overnight and the dash constant problem is cured. except now my battery light, red oil light are on and my dash computer selector on blinker lever still doesn't work.
Any ideas?
BMW CCA #: 399644
Old 09-10-2012, 06:38 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Any ideas?
Sure sounds like an electrical issue. I'd take the battery to be tested and if possible trickle charged. Just sounds like too many weird issues to be anything but low voltage.
Old 09-10-2012, 06:43 AM
Quick update, now my clock on my dash computer is going haywire, its as if the button used to set the time is being held down...
BMW CCA #: 399644
Old 09-10-2012, 06:46 AM
smolck's Avatar
ROLL TIDE!
May want to take the alternator off and take it with you to have it tested with the batt. I am assuming the car isn't driveable.
Old 09-10-2012, 07:10 AM
the car drives fine, can a place like autozone test alternator along with battery?
BMW CCA #: 399644
Old 09-10-2012, 07:24 AM
smolck's Avatar
ROLL TIDE!
Yea, just have to let them in the trunk to test alternator. some of them get all freaked out by the battery in the trunk thing.
Old 09-10-2012, 07:42 AM
oh ok so i can drive my car there without having to remove anything. thanks smolck
BMW CCA #: 399644
Old 09-10-2012, 08:12 AM
I'm at autozone right now, I have two codes:
P0365 cam shaft sensor bank b
P0455 emmissions no flow
Does this help at all? Charging system is being tested now...
BMW CCA #: 399644
Old 09-10-2012, 08:21 AM
Charging system tested out to be fine. This is turning into a nightmare
BMW CCA #: 399644
Old 09-10-2012, 10:04 AM
What would disable speedo, mpg gauge and computer selector? Also trigger red oil light and battery light with no related error codes?
BMW CCA #: 399644
Old 09-10-2012, 12:35 PM
mawana's Avatar
Mein Auto: e46 ZHP
Simple things first, get the battery recharged or replace it altogether. Been there, only difference is I didn't have a red oil light, and my problem was solved by recharging the battery at AZ for free. And I'm afraid, a bad battery might have done your alternator too, that's why you are getting a battery light!
[How can AZ say charging system is fine when you have a battery light? Bozzos!]
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 09-10-2012, 01:40 PM
Well my hunch is there is a short, my whole instrument cluster is messed up so a false positive red battery light it's not out of the question IMHO,
BMW CCA #: 399644
Old 09-10-2012, 01:57 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
I had a similar issue once. My dash would randomly turn off and go back on while driving making an awesome sound. Or none of my gauges would work at all upon start up. it turned out to be my ignition switch. I replaced it and the problem hasn't came back since.
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
BMW 2006 M3 - stock - SOLD
Old 09-10-2012, 02:55 PM
That's what I hear can cause strange electrical issues. I wish it would throw a fault code >
BMW CCA #: 399644
Old 09-10-2012, 07:03 PM
I already ordered a cam shaft position sensor but that is an unrelated issue.
After doing some research i found out that a failed speed sensor located in the rear passenger wheel will cause the speedo odometer and mpg guage to fail. It will also trip the abs, dcs and brake lights to come on which i do not have, but i do have a red oil light and red battery light.
can anyone make sense of this?
BMW CCA #: 399644
Old 09-11-2012, 12:35 PM
Well I know I have not generated a lot of interest in this thread but I have o update regardless:
My car sat overnight until 2:30 today. Upon starting battery and oil light have shut off, my speedo and mpg gauge is back and my dash computer selector buttons work. Which is to say all electrical issues have subsided. I am guessing that whatever got wet and shorted out has dried and return to normal. For how long I don't know because if this is the case I'm betting corrosion will set in.
BMW CCA #: 399644
Old 09-11-2012, 12:58 PM
TheMalibuMafia
Let us know how it is driving it the next few days.
TheMalibuMafia.com
