Old 09-30-2012, 06:25 PM
Alpine745li Alpine745li is online now
745Li
Mein Auto: BMW 745LI
Do you get any type of shimmy or shake on your spacers? Mine are perfect no shimmy or shake.
Old 09-30-2012, 06:32 PM
745Li
Originally Posted by bayerisheteknik View Post
you use 5 on each side and they go through spacers/wheels...btw i use 275/35/20 rear and 245/40/20 front tires...someone is using 45 front and 40 rear???
Image and video hosting by TinyPic
I currently have 45 front and 40 rear. With the Eibach lowering springs and Eibach rear spacers I dont have any issues. If I hit a dip on the freeway my right rear fender barely rubs. Im just trying to make my stock look a little more sportier and with the combination of the springs and spacers it got the job done! Geah!
Old 09-30-2012, 10:17 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: 750Li
Thanks for posting up , I do t see much wrong with he front , I might get some spacers for the rear and leave it at that
Options:
Camera Package, Convinience Package, Driver assistance Package , Front & Rear Luxury Seating Package, premium Sound, Rear Seat Entertainement Package, Sport Package, Massage rear seating, Ceramic Controls, Active Cruise control, Smarth Phone Integration, Night Vision, Headsup Display, Sat Radio, Leather Wrapped Dashboard & Sport steering Wheel .
Old 10-04-2012, 01:16 AM
pmpn8ez's Avatar
pmpn8ez pmpn8ez is offline
Mein Auto: 04 BMW 745Li E66
Originally Posted by Alpine745li View Post
Here are pictures of my wheels installed on 15mm front & 20mm rear spacers.
Looks really good! I just ordered 20mm for the fronts and 30 for rears. I'm getting the 30mm from CLOWNIN745
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
Old 10-06-2012, 12:02 PM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Any input where to buy a good recommended set f spacers ?
Options:
Old 10-08-2012, 07:27 AM
pmpn8ez's Avatar
ecstuning.com
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 08:02 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Originally Posted by pmpn8ez View Post
ecstuning.com
Thanks a lot , I'm purchasing front a rears , are they specifically fronts and rears fitments or this will fit all around ?
Thanks again
http://www.ecstuning.com/BMW-E66-750...cers/ES260936/
Options:
Old 10-08-2012, 08:07 AM
pmpn8ez's Avatar
The spacers can go rear/front. Measure how many mm you need to get the look you're going for and then order the proper size. Read what is included in the kits. With spacers, it is highly recommended you use longer bolts. Some kits come with it and some are just the spacers.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 08:13 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
I was going with 20MM all around , but now i see you running 30MM in the rears , that looks nice . any bigger pictures ?
Options:
Old 10-08-2012, 08:34 AM
pmpn8ez's Avatar
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 08:37 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Appreciate the pictures , might stick with 20MMM , Anyways big difference how it changes the stance .
Options:
Old 10-08-2012, 08:55 AM
pmpn8ez's Avatar
From your avatar, I see you have a sports package. Your car already sits lower. I would go with 20mm or 15mm for rears to prevent rubbing. I actually have to roll my fenders today. Went out last night and the rears rubbed on big dips.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 08:57 AM
pmpn8ez's Avatar
Here's how it looks 20mm at the rears.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 09:01 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Oh i see thanks for the detail
Options:
Old 10-08-2012, 09:36 AM
pmpn8ez's Avatar
Your car looks really good. Love those stock 20's.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 11:00 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Thanks man , so you went with the H&R's ? if so did the 20MM Came with longer bolts ? they are at $83 bucks for a set of 20MM H&R . but the ECS looks top notch quality as well ?
Options:
Old 10-08-2012, 11:18 AM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
just pulled the trigger on a set of ECS 20MM front and Rears , easier as it comes with bolts ready to rock .. will post up pictures when i install them .
Thanks for all the great info here fellas .
Options:
Old 10-08-2012, 12:12 PM
pmpn8ez's Avatar
Pretty sure ECS is good quality as well. Be sure to properly torque the bolts on the wheels/spacers. Recheck after a day and retorque the bolts. Check it often to make sure everything is bolted on properly for safety. Your car will look great with spacers. Those wheels are really nice but definitely swallowed in. Will look much better flush.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-08-2012, 12:47 PM
M4XBMW7's Avatar
TTurboFest
Mein Auto: 750Li
Exactly my thoughts , and will do as you recommended . Thanks again .
Options:
Old 10-11-2012, 12:44 PM
nagelmotox nagelmotox is offline
Mein Auto: 07 BMW 750i
hey guys... I just got some 20mm spacers for my car and took them down to firestone to have them put on with my new conti's I just got. They told me they wouldnt put them on because it's a liability and I shouldnt do so and it also takes a special technique to put them on? wtf... don't you just put the deeper lugs on in a star pattern as you would without and be good with it? Thanks!
Old 10-12-2012, 02:32 PM
pmpn8ez's Avatar
Most tire shops won't use spacers or recommend them and won't install cause of liability reasons. They are safe to use as long as you mount them properly and torque the bolts to spec. Make sure to recheck after a day of driving and recheck often. When you mount the spacer onto the hub, be sure it's flush all around, no gaps. Bolt on the wheels star pattern with longer lug nuts. Be sure they turn 8-10 times before tightening.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-12-2012, 02:41 PM
Thanks.. i went ahead and did them yesterday.. seem to work fine!
Old 10-12-2012, 03:17 PM
pmpn8ez's Avatar
Can't wait to see pix!
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
Old 10-12-2012, 03:24 PM
http://s58.photobucket.com/albums/g2...-03-17_731.jpg
Nothing to exciting... those are black powder coated stockers on it.
Old 10-12-2012, 03:34 PM
pmpn8ez's Avatar
Looks really good.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Akebono Brake Pads
JL Audio 500/1 Amp
