Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 02-17-2013, 06:27 AM
535iSport 535iSport is offline
Mein Auto: 2009 535i
Seat Belt Chime
Hi Folks, how do I turn off the chime the car makes when you take your seat belt off? It's driving me crazy, it seems to happen even if i'm parked but have not exited the car yet....
2009 535 i sport
Old 02-17-2013, 08:33 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Shut down the motor. Why would you get out of the car with the motor running?
Old 02-17-2013, 10:22 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
You take your seat belt off before you come to a stop. Don't do that. Wait until you get to the parking spot before you take your belt off (the vehicle is still moving). My wife does this when I drop her off in front of a store sometimes and it drives me nuts. The passenger chime does turn off as you lift off the seat however. It's just nuts that I never realize she took it off until I'm about to come to a complete stop when the chime starts.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 02-17-2013, 10:31 AM
boramkiv's Avatar
Propellers Up Front
I do this sometimes, especially since I have comfort access. I can shut the door with the engine running, touch the handle to lock the car and return really quick. If I forgot something and had to run back to work, or in the house to retrieve it.
This is illegal in Germany though.
Old 02-17-2013, 10:54 AM
pjinca pjinca is online now
USAF Pararescue Veteran
Mein Auto: 2008 550i
It can be coded out, but it's easier (and cheaper) to do as suggested above.
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 02-17-2013, 01:35 PM
Thanks pjinca, I turned this off in my truck with a code. Will look into it further on the internet. George t, thanks for nothing.
Old 02-17-2013, 01:45 PM
Find someone in your area experienced with NCS Expert and you can get a bunch of things coded - for example I have: Digital speedo in my gauge cluster, I can raise AND lower my windows with my key fob (typically only available in Europe), I can auto fold my mirrors with key fob, if you don't have real time traffic info in the NAV this can be enabled on any E60 with at least a 2007.1 NAV disc, I also have my fogs enabled with highbeams.
2006 Jeep SRT-8
Old 02-17-2013, 01:51 PM
boramkiv's Avatar
Propellers Up Front
Are you sure about this? Do you need a traffic module installed or something?
I need to look into this.
Old 02-17-2013, 01:55 PM
No you don't, it gets the info from the radio (AM) so you just need it coded. I can PM you my buddy's email address, he coded everything in my previous car AND this one. I had one of the FEW 2005 E60's with Real Time Traffic
Here is a list of what he coded for me, these are based on build dates, but they are pretty generic - differences would be if you have LM1 vs LM2 and CCC vs CIC.
>> Disable legal disclaimer
>> Enable welcome lights (LM2 only)
>> Next source skips AM Band
>> Climate Seat one touch shortcut
>> LCI AE stay at full brightness with low beams on
>> Enable/disable DRL on pre-LCI
>> Turn signals on (reduced brightness) with parking lights or low beam
>> Soft/Hard fade on/off any external lighting (LM2 only)
>> Allow high beam with fogs
>> Enable/disable cold/warm/iDrive checking for bulbs
>> Disable eyebrow
>> Enable BFD (flashing brakes when braked hard)
>> Double flash hazard light
>> Digital speedometer
>> Cluster always on (default on Ms)
>> Disable continuous door gong with key in ignition
>> Close windows and sunroof with key
>> Disable double pull to unlock (unlocking mechanism is tied to
key fob's setting in iDrive)
>> Always show fan setting even in Auto
>> Blinkers in HUD
>> Auto-fold mirrors with key
>> Lower sensitivity for auto headlight
>> Real time traffic information in NAV +$20 (requires 2007 or newer NAV disk)
>> Pathway lighting via key
2006 Jeep SRT-8
Old 02-18-2013, 06:24 AM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
pjinca:
When you mention " Real time traffic information in NAV" is this what you are referring to?
It is an up-to-date list of traffic problems and depending on your settings, the nav routing will consider these problem areas.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim,
Gray Dakota Leather
Old 02-18-2013, 10:37 PM
Originally Posted by legend700 View Post
pjinca:
Yes, that is what I am referring to, also if you look at your map again the little black arrows will display traffic on a given roadway, the closer they are together the heavier the traffic.
2006 Jeep SRT-8
Old 02-19-2013, 06:07 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
>> Disable eyebrow
>> Digital speedometer
>> Blinkers in HUD
Do you know how much he charges for all those coding
http://tinypic.com/r/vwzua1/6
Old 02-19-2013, 06:23 AM
legend700's Avatar
Thanks. Did not know about the black arrows.
Gray Dakota Leather
Old 02-21-2013, 11:07 AM
E92-Lighting's Avatar
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
code it out, i am pretty annoyed by it as well
