Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 09-08-2012, 10:45 AM
QTL QTL is offline
Mein Auto: 335D
Question 335D oil pan removal?
I was wondering if any has tips the can offer me on how to remove the oil pan on a 2011 335D? I got it lose and unbolted, took the stiffner off, tried to drop the front end a bit and lift the engine at the same time. however i need more clearance to tilt the pan and slide it back. Do i need to unbolt the engine from the mounts, or remove the tranny in this case...?
Old 09-22-2012, 03:06 AM
BMWFatherFigure's Avatar
Old School
Have not worked on this particular model. For other similar I have disconnected engine mounts and lifted engine slightly. Normally ok but keep a strict eye on over tensioned wires, hoses and cables. Expect to get a 4-5" lift at the front of the engine.
Current:
Previous:
