Old 09-11-2012, 08:53 PM
JEG23 JEG23 is offline
Mein Auto: 550i
Originally Posted by marcosg View Post
I do NOT have an extended display and I have this icon. I do have kids and when anyone take their seatbelt off while driving, it lights up with an audible warning.
Thanks marcosg.
Shawnsheridan, what kind of display you have?
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 09-11-2012, 09:03 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by JEG23 View Post
Thanks marcosg.
JEG23
No HUD / Extended Black Panel. Just the regular display. I will have to check the icon out myself tomorrow.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 09-12-2012, 03:27 AM
marcosg marcosg is offline
Mein Auto: 2016 BMW F15 40d M Sport
Attached is a picture of my display with the seatbelt symbol. I have HUD with Professional Nav.
2011 BMW F10 528i M Sport
Old 09-12-2012, 11:54 PM
fhinfo fhinfo is offline
Mein Auto: X3 F25 20d xDrive
Updated:
Finally, I found someone to be my passenger in the rear seat and did the test. Unfortunately, no go! The reminder never change even though the rear passenger fastened the seat belt or unfastened after fastened. The indicator remain the same status. My guess is maybe we didn't activate the sensor at the rear seat or there is NO sensor at all?
Old 09-13-2012, 03:01 PM
Originally Posted by fhinfo View Post
Updated:
Well that sucks!
Old 09-13-2012, 08:08 PM
Mein Auto: 550i
Originally Posted by shawnsheridan View Post
Well that sucks!
I does indeed suck. I have looked everywhere to see if I can find a sensor that can be activated. I have a feeling that US spec cars do not have backseat seat belt sensors.
JEG23
2011 550i
Old 09-13-2012, 09:19 PM
JEG23
Hard to believe if that is the case. My kids are back there all the time, but they wear their belts, so I have never noticed. Tomorrow on the way to school, I will have them disconnect and see if I get any kind of warning.
Old 09-14-2012, 06:43 AM
ImSW1 ImSW1 is offline
Mein Auto: F10
Having pulled my rear seats out multiple times I can tell you that my US spec 528 doesn't have rear seat or seatbelt sensors. There's no extra wires running into the seatbelt lock buckles or any wires that get disconnected to pull out the rear seat bottom. If you look on realoem, EU countries have a "For vehicles with Extra package, EU-specific," package associated with their rear restraint systems so unless the US sensors are super-duper bluetooth or have some other style of communicating with the car, my guess is the rear seat belt notification option is a hardware as well as coding issue.
On an associated note. It's really easy to remove the rear seat if you have the non-split rear seats. Just grab it on each front corner (bottom pad) and pull up. It's just held in with a compression clip. The rear seat back uses tabs on the upper rear portion and two torx bolts at the bottom of the seat back. Fun weekend project to learn more about your car. If you have the split rear seats it's a little more complicated, but not much more.
Sean
Old 09-14-2012, 07:12 AM
Mein Auto: 550i
Sean
@Sean,
Thanks for that information. I have been pulling my hair for days searching the missing code. I should have just checked my seats before.
JEG23
2011 550i
Old 09-14-2012, 07:17 AM
Yep, no rear sensors, or if they are actually there, they are not enabled.
The coding of GURT_FOND_STATUS being in KOMBI obviously is the icon only. I would think that if the actual sensors are there and can be enabled, the coding would be in ACSM.
Maybe these (Seatbelt Contact - Rear Left, Right, & Middle):
Gurtkontakt_Hinten_Links = nicht_aktiv
Gurtkontakt_Hinten_Rechts = nicht_aktiv
Gurtkontakt_Hinten_Mitte = nicht_aktiv
My front Driver and Passenger ones are enabled:
Gurtkontakt_Fahrer = aktiv
Gurtkontakt_Beifahrer = aktiv
Or Possibly these:
FGS_Sensor_Links = nicht_aktiv
FGS_Sensor_Rechts = nicht_aktiv
FGS_Sensor_Mitte = nicht_aktiv
Can someone with functional Rear Seat Belt Status working check these 6 settings and tell me if they are aktiv?
Old 09-14-2012, 07:20 AM
...If you look on realoem, EU countries have a "For vehicles with Extra package, EU-specific," package associated with their rear restraint systems so unless the US sensors are super-duper bluetooth or have some other style of communicating with the car, my guess is the rear seat belt notification option is a hardware as well as coding issue.
Sean
I guess that is "S230A Extra package, EU-specific", which I have been wondering what the hell this was.
Old 09-14-2012, 07:59 AM
Mein Auto: F10
Shawn,
It looks like that's definitely the pacakge, since it shows "Extra package, EU-specific S230A=Yes" on realoem. It looks like these are the part numbers we'd need to get the rear restraint package up and running on a US spec car. The only other issue is; I don't remember there being any unused connectors under the rear seats of my car. I can get the buckles from some friends in Germany but I think we're chasing a rabbit down a rabbit hole on this one.
LOWER BELT REAR LEFT - 72117243273
LOWER BELT REAR RIGHT - 72117243274
LOWER BELT REAR CENTER - 72117243275
None of these part numbers are in the US parts catalog.
Sean
Old 09-14-2012, 08:03 AM
Mein Auto: F10
Or Possibly these:
Really Shawn,
When you're writing the code the next 5 series could you make all these values "aktiv"? I'm going to start calling you the "Engineer"
Sean
Old 09-14-2012, 08:08 AM
Mein Auto: F10
@Sean,
JEG23
JEG23,
No problems. That's the great thing about this forum. I'm amazed about how far coding of the F-series has come in such a short time. A true community effort, albiet driven by ShawnSheridan, DreamCar, svache and a some other keyplayers.
Sean
Old 09-14-2012, 09:17 AM
Really Shawn,
Sean
aktiv is good!
Old 09-14-2012, 11:54 AM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
i've just take a look at my f30 and i don't think there's a sensor under the seats
the 3 red passengers in bc appears after engine start with and without passengers in fond
only if the belt is stucked the green symbol appears
and its now bounded on the correct side. i can pull the left belt in the right hole - Result: the right symbol will be green
Old 09-14-2012, 11:56 AM
That is why I want to know these Seatbelt Contact settings:
Are your's all set to aktiv?
Old 09-14-2012, 03:03 PM
Mein Auto: BMW
jap
mine are all aktiv
Old 09-14-2012, 03:11 PM
jap
mine are all aktiv
I was sure they would be, but thanks for confirming it.
So, if the U.S. cars actually have the Seatbelt Contact sensors, then these three codes should enable them to work with the KOMBI icon.
Old 09-14-2012, 04:42 PM
I tried,
I make all three codes to aktiv then nothing happened at all. So, NO SENSOR!
Old 09-14-2012, 04:50 PM
I tried,
Game over.
Old 09-16-2012, 10:59 AM
I tried,
Wait. Did you test these 3 too?
Maybe these too (but there is not one for the middle?):
SBR_Sensor_Hinten_Links
SBR_Sensor_Hinten_Rechts
Old 09-16-2012, 11:06 AM
Well, I have turned these three FGS_Sensor to aktiv but still nothing happened. I will try to turn SBR_Sensor to aktiv and try later. I have a question, if I turn off the seatbelt reminder at the front, does it cause the rear seat reminder disable as well?
Old 09-16-2012, 11:15 AM
I thought about that too, but I don't think so. The existing coding for disabling the Seatbelt warnings are specific to the Driver, Fahrer (FA) or the Passenger, Beifahrer (BF), which should have no affect on the Rear Left, Middle, and Right ones.
Old 09-18-2012, 02:11 PM
cuorealfa1 cuorealfa1 is offline
Mein Auto: 5er GT 535d
hello
what did you code in the Kombi?
did you set "3_sitze / Werte=02" ?
because in the description it showa different values:
00b = kein FondGurtStatus
01b = 2-sitzer Ruecksitzbank
10b = 3-sitzer Ruecksitzbank
may be the Werte-Vaue should be set to 10b instead of 02 ?
Or am i mixing up things now?
@AutbahnCowboy
what values do you have in the KOMBI?
2010 BMW 535d GT
