Old 09-09-2012, 08:46 AM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Need help with finding this part # for valve cover mounting.
I circled the part in the picture which I borrowed from Fudman
This stud snapped when tightening the valve cover cap after installing a new VCG(I think my valve cover is warped, keeps leaking a tiny bit no matter what) I'm thinking its just a stud with a hex nut to keep it secured. Is this the correct part?:
http://www.ecstuning.com/Search/07129908102/ES16194/
Old 09-09-2012, 08:57 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
If realoem lists 11 or so of these as the quantity used by the car, that's likely the guy. If you have a metric thread gauge, you can confirm fairly quickly.
Old 09-09-2012, 09:15 AM
Fudman's Avatar
Fudman Fudman is online now
The part no. is 07129908102 (for an M54) which is a match, per realOEM. The threaded bolt stud shown is also the same size M6 x 30. You can remove your old one using a dremel tool to cut a slot in the top of the stud and then back it out with a flat blade screwdrive. Careful not to cut into the valve head. It the bolt stud is flush or recessed, us an EZ-out. Use two nuts locked together to insert the stud.
Old 09-09-2012, 10:11 AM
eparayno's Avatar
Thanks guys. Fudman I will use the double nut procedure. There's enough of the stud left to fit another nut. I can't believe how easily it snapped while tightening down the cap nut.
