2006 Z4 Rear end shuttering/cornering??? - Bimmerfest - BMW Forums
Old 09-10-2012, 12:20 PM
dtower dtower is offline
Mein Auto: 2006 Z4 Coupe
I have a 2006 Z4 3.0si Coupe with 13,000 miles. Just recent while exiting from the freeway the rear end (diff) jerks and catches jerks and catches and I know i'm not loosing traction? I have had this happen on vehicles with limited slip and just required an oil change with foaming additive? Anyone else had this issue ?
DT
Old 09-11-2012, 04:50 AM
pokeybritches pokeybritches is offline
Mein Auto: G-Power & ESS Z4Ms, VF Z4
Check for loose sway bar bracket bolts in the rear. You can do this without lifting the car.
G Power Z4M and VF Engineering Z4 3.0i
