E36 (1991 - 1999)
Old 09-10-2012, 07:00 PM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inze Fatherland 325
E36 obd1 to obd2 coversion. Can it be done?
So ive been restoring a 96 328i for a few month now and my boss just went and bought a 92 325i with 108,000 kms for a 1000 bucks and is now askig me if i want it. If i bought it i was thinking of maybe swaping everythig from the 328i into that unibody because its flawless except for the paint and one ding in the rear passenger quarter panel. Im not concerned about the time or labor involved i just want to know if the unibodys and identical and if i rip it down to a shell can i sway the obd2 into this obd1 car with no issues or anything. Thanks let me know
Sent from my SGH-T989D using Bimmer App
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 09-10-2012, 08:58 PM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Yeah, if you want to swap everything you can do it, the body is the same....Or...... you can just swap the motor and trans, then convert the motor to OBD1 and use the same electronics from the OBD1 car. You can ask CJ about the conversion, or just google it. There are about 10 things on the motor itself that need to be changed, then you will be good to go.
Good luck
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 09-11-2012, 06:08 AM
jkmeisl's Avatar
Josh
Good luck
the 92 is an automatic and the 96 is manual 5 speed ZF transmission, so I would be swaping that in for sure. the 92 is from japan, so the paint is done for, so I'll have to paint it which is fine I like doing all this work anyways. its kind of a hobby for me. i think once my 96 is completely stripped and my new panels are in and the uni body is painted I'll just swap everything over.
Old 09-13-2012, 05:59 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Yep, it can definitely be done. It's not that hard either. You want to use the whole intake setup, wiring harness, DME, etc, from the M50 (M50 manifold is a performance upgrade anyway).
My thread on the swap doesn't have much instructions, but you should get a basic idea of what needs to be done. Feel free to ask me any questions.
http://www.bimmerfest.com/forums/sho...761&highlight=
-CJ
Old 09-13-2012, 06:19 AM
jkmeisl's Avatar
Josh
yup I bought the car of a grand, and I'm waiting to finish up the 96 unibody then I can just swap EVERYTHING over. should be fun. but the idea is to use all the better pieces from both cars to make 1 perfect car and then 1 OK daily driver or somthing. all Im missing for parts is a set of m3 side skirts and m3 rear bumper. heres pics of the 92 and one of le 96
ID:	341669   Click image for larger version
ID:	341670   Click image for larger version
ID:	341671   Click image for larger version
ID:	341672   Click image for larger version
Old 12-07-2013, 01:34 AM
BustedE36 BustedE36 is offline
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
Hey I really need help with my s50 swap into my 97 318. I did the swap hooked everything up and had no spark .. so I went and pulled a body side harness off another 95 m3 and im wiring it up right now but some of the pins are off.. would this cause a problem?? Please help beamer love !
Old 12-07-2013, 09:48 AM
jkmeisl's Avatar
Josh
could be a million things man. go through everthing, make sure everything is hooked up, do your research make sure you have the right ECU you might need something as simple as a EWS delete chip. check that out
Old 12-07-2013, 11:13 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Have you downloaded the Bentley manual? If not you should. It has complete wiring diagrams for all the E36 variants.
Also make certain you have all the grounds installed that go with the S50 install.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-07-2013, 12:45 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
the swap will be complicated as you are obd2. even more so due to it being a 4 banger.
the //M harness you got is from an obd1 chassis, so it may not be compatible to your chassis. you *really* will need to use an obd2 wiring harness and dme (reflashed) to be able to do this swap from what i have gathered.
obd1 is much easier as it doen not involve 'flashed' modules, but is even easier with an m50 to s50 swap....
df
Old 12-07-2013, 06:48 PM
cj.surr's Avatar
some kid
So, if you're going to do this swap, you know that your car will not pass any emissions test where they plug in a computer, right? Also, you need to bypass the EWS. That's why you're not getting any spark. Google how to bypass the EWS and you will find a bunch of info on it.
-CJ
Old 12-09-2013, 11:29 PM
I don't need to pass emissions where I live and I did delete the ews crossed the right wires but I think that I need different sensors with that setup .. I have the 413 red label. Im going to try and do this chassis wire swap and if it doesn't work idk what to do, has anyone done the obd1 engine swap into an obd II chassis ?
Old 12-09-2013, 11:31 PM
I've done the reasearch I just need to talk to someone that knows what they are doing. I can do the work no problem.
Old 12-10-2013, 06:42 AM
jkmeisl's Avatar
Josh
wish I could help you more. I'm in the middle of rebuilding the m52 that I'm planning on swaping in at the moment so I'm no where near the point you are...
but here's couple threads I've looked at and have been a great help
http://forums.bimmerforums.com/forum...52-to-OBDI-M52
http://forums.bimmerforums.com/forum...77#post7482777
Old 12-10-2013, 06:48 AM
Hellawut??
Mein Auto: who knows?
I wonder if bustede36 installed the e46 front bumper all by himself
-Franklyn
Old 12-10-2013, 10:25 AM
Eight no need to talk ****, im sure you haven't even touched base on how far I am into this car. So if you have no know knowledge your thoughts are invalid.
Old 12-10-2013, 10:26 AM
Thanks JK for your help.
Old 02-29-2016, 11:50 PM
jmelias jmelias is offline
Mein Auto: bmw e36 m3
hey man I'm planning on swapping a m50 from a 1995 m3 in my 1996 318i what should what should I look for I have never done it be and idont know whatto look for
