Old 09-11-2012, 06:54 AM
j_schroeder's Avatar
j_schroeder j_schroeder is offline
Mein Auto: 330ci
Fuel pump
How loud should the pump be while running? I can hear the distinct whine from the pump since I've owned the car and I'm just curious since I will be dropping the tank to weld in the subframe re-enforcement plates and will replace while I'm there. The car also has a slight gradual stumble when its cold, and I feel the rpms drop momentarily when I slow to a stop.
btw vanos has already been rebuilt.
Sent from my DROID2 using Bimmer App
2001 330CI
Old 09-11-2012, 07:34 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
Some people say that when your pump gets louder that it is failing. I have replaced pumps before that were said to be loud just to have the new pump sound the same as the old. I would run a fuel pressure check and as long as it comes out ok I don't think that I would replace it unless you really want to.
Old 09-11-2012, 08:42 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
I can't hear my fuel pump unless I specifically listen for it without the car running.
How many miles on your car? It seems that E46 fuel pumps fail anywhere between 80-150k... might be a good idea to swap it out.
Old 09-11-2012, 11:38 AM
Mein Auto: 330ci
The car is an 01 with 127k on her. You can definatly hear the pump when your standing outside of the car.
What is the acceptable range for the fuel pressure of an e46?
2001 330CI
Old 09-11-2012, 11:44 AM
Mein Auto: 330ci
O forgot to mention I have no idea if the fuel filter was ever changed either so I'm not sure if that would make a difference or not but I guess it wouldn't hurt.
2001 330CI
Old 09-11-2012, 02:11 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
At that mileage replace the pump and filter
www.bmaautoparts.com use discount code spece30
