E30 (1982 - 1993)
Old 09-11-2012, 04:58 AM
darko691 darko691 is offline
Mein Auto: Bmw 318i
Problem with 324 TD
Hello i have a problem with my 324td 1990y .My diesel injection pump has destroyed.
http://static.bmwfans-LINK BLOCKED R...c/MTgxMV9w.png
I change it with another pump, the car start it's okay. But i decided to make a little ride 40 km, everithing was ok but when i stop for 2-3 sec the car turn off. with a lot of effort the car star the engine and i drive it to home.I put it in the yard and now does not want to ignite, i dont know what could be the problem??
I don't drive too fast, I just fly to slow
Old 09-11-2012, 03:26 PM
downhiller's Avatar
livin large
ooo a diesel. lucky man. have you checked to see if the glow ignitors are working? also is that a 24v system? thats more curiosity more than anything
Old 09-12-2012, 12:24 AM
Mein Auto: Bmw 318i
Yes everithing is ok but the car wont start the engine.
p.s It's my daddy's car
Old 09-12-2012, 07:42 PM
downhiller's Avatar
livin large
did you bleed the fuel system, you can have air in the fuel filter. highly common in diesels.
Old 09-12-2012, 09:56 PM
BMWFatherFigure's Avatar
Old School
Blocked fuel filter?
Old 09-13-2012, 07:39 AM
Mein Auto: Bmw 318i
It doesn't have a air in the filter because i replace it with the new fuel filter.
Old 09-13-2012, 09:50 AM
hornhospital's Avatar
D'oh, You Kids!
That is precisely why it could have air in the fuel system. You changed the filter but did not bleed the system, correct? The diesels aren't like the gas motored cars. You must bleed the air out of the fuel system if the fuel line has been opened anywhere (including changing the filter).
Quotes to live by:
Old 09-13-2012, 12:12 PM
Mein Auto: Bmw 318i
I bleed all the air in the fuel system/line but it doesn't start the engine yet
Old 09-13-2012, 06:53 PM
downhiller's Avatar
livin large
well, if the glow plugs are working correctly, the last option in your case will be injectors. unless the new fuel pump doesnt have enough pressure. diesels are very simple in a complex way. now a very curious question that does relate. does this have a fuel distribution block/center like mercedes?
Old 09-14-2012, 02:32 AM
Mein Auto: Bmw 318i
The fuel pump have enough pressure because when i replace it the engine start perfectly, but when i decide to drive it a little 50-60km, the engine turn off and now it don't wont to start again I think if there have any sensors/electrican problem with the car??
Old 09-15-2012, 08:00 PM
downhiller's Avatar
livin large
if its a 90, then there should be a crank positioning sensor. what im trying to figure out is if bmw went to injectors around that time. and i cant find anything. thanks google.
