E90/E91/E92/E93 (2006 - 2013)
#26
My 2008 MT 328i (E92) has never shown which tire is low, which is a nuisance when a wheel cracks and the air starts to leak out. I would have assumed that BMW doesn't like to use corner-specific TPMS because there isn't a reliable way for the car to "know" which sender is in which corner, if for example someone rotated the tires.
#27
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion |
#28
BMW's system is best. Here's what happens on some of the competition. As you said, there is a code sent by each monitor identifying which one it is, and therefore which tire location is sending the signal. If the tires are rotated the signal will still identify the same tire but now it is at a different position. Had a customer who kept getting a "Right rear tire low" notification. She kept adding air but the notice stayed on. It turned out to be the left front which was low, the shop which rotated the tires did not run the reset procedure. It can be lengthy, and it requires some special tooling to identify the monitors' code numbers (hexidecimal!) Last edited by DSXMachina; 10-08-2012 at 07:53 AM. |
#30
Thanks. Makes much more clear now. I knew what I meant to say....
#31
TPMS Sensors calibration
The statement that somehow the car would lose the intelligence about sensor locations if the tires are rotated is simply NOT true.
Any car I had with sensors (Jeep, Infinity) - would automatically re-learn the sensor location in a few minutes (including after rotation using full size Spare). To say that BMW system is "The best" because it does not provide the information that "may be confusing to the driver" can only come from BMW. I hope hat there is enough push back from the customers to make BMW change the system to become usable. |
#33
We were speaking in reference to having two sets of sensors (winter and summer) as some people have. The Infiniti (you would think you would spell it correct if you had one ) absolutely does not re-learn a thing unless you bring it to the dealer. If you simply swap tire locations it will not know they were swapped. In other words it will still think the right front is on the right front even if you have moved it. It's a moot point because the Infiniti (the G35 I had at least) didn't tell which tire was low. It simply turned on a light indicating a given tire is low. So if they are swapped, who cares. If you put new sensors on and didn't re-program you have to go to the Infiniti dealer. Short answer: What you said is not correct. The Infiniti (like most) has one receiver to sense all 4 sensors. It has no clue about location, it simply knows the sensors are close by.
#34
I know this thread mostly talks about the ability for our cars to tell which tire is low. My car still clearly shows which of the 4 tires is low. It went off just a few weeks ago. Not sure if that is the case on all firmware updates and all model years. |
#36
As for knowing which tire is low or flat I see no reason the vehicle couldn't determine this based on the information being fed to it by each individual receiver. I.e. if the front passenger receiver is sending a tire pressure of 28 PSI (assuming 28 PSI is out of specification) then the system can, based on the passenger receiver sending the 28 PSI pressure, alert the driver the front passenger tire is low. I see no reason for the system to require the sensor in the tire be paired with the receiver. Last edited by sunny5280; 11-07-2012 at 01:01 PM. |
#38
![]() So, for one receiver systems, the simplest means is to tell the receiver which sensor serial number to associate with which corner of the vehicle. This is why Infiniti wanted to charge me $60 to walk around the car and read each sensor serial number (with a tool) and program the receiver. That would be $60 twice a year when I swap tires. I lived with the warning light all winter instead. The BMW has 4 receivers, so it works as you are saying. It's much easier to detect location at a much closer distance. Although, now that you mention it, I never tired swapping wheels without doing a reset. There's probably a good chance it might simply start reading the new sensors on the new wheels. My pressures are always different (summer staggered wheels versus 17" same size). I always reset when I swap tires for this reason alone. Perhaps if you had same size tires, same temperature, same pressures it would just work. Still would make sense to reset because the odds that is all going to line up is small. |
#39
What tells the sensors to transmit when they are on the road? The answer is accelerometers and programming that tells the sensor to transmit at specific intervals and speeds. When a sensor is not turning, it is not typically transmitting information. When it is moving, it is transmitting information in 15, 30 or 60 second intervals depending on the application. By not transmitting a signal all the time, the battery can last up to 10 years. When a vehicle is not moving for a defined period of time, the sensors will go into a rest or sleep mode. It may take between 10 to 20 minutes for the sensor to enter this mode. Some systems (*) require the sensors to be in this mode when the relearn procedure is initiated. This is why some systems require the vehicle to sit for at least 20 minutes. (*) not sure if this applies to our BERU systems.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
