E60 (2004 - 2010)
Old 09-17-2012, 09:15 AM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is online now
Bimmer Craze
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Universal garage door setup
Guys,
I am not sure what i am missing but i am unable to setup this.. I am checking the below youtube and doing the setup step by step but in vain
I have a lift master for my garage..
Any help is much appreciated..
Thanks in advance
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |Front/Rear Cameras | Escort 9500ix |
Performance-Cobb Stg2+FMIC ST Agg | Injen Intake | BMS OCC | ER anodized FMIC |AR DP Catted |TIAL Q BOV | ER Charge pipe | Spacers (F 12mm/ R 18mm)
Cosmetic-32w Cree LED AE | Xenon HID Fog Bulbs | M5 trunk & Roof spoiler rear | XENON white Emblem LED BG Light | LED Side Marker | M5 bumper | Hamann LP | License & Interior LED lights| Tinted glass |
Old 09-17-2012, 04:16 PM
mzambrana78 mzambrana78 is online now
Mein Auto: 1985 325e
Man i cant get mine to work for the
Life of me. Pisses me off. I tried so many times that I must habe captured my neighbors code. I finally saw him leave and my garage would open as his would close. Let me know if u figure it out!!
Old 09-17-2012, 04:22 PM
bimmerguy288's Avatar
bimmerguy288 bimmerguy288 is offline
Mein Auto: 2010 535iX
Originally Posted by Shahul_BMW View Post
Guys,
Thanks in advance
Do you have a garage door with rolling code?
Old 09-17-2012, 05:11 PM
I tried both options like 20 times. I have a brand new house and new lift master opener. Its not the old school openers with the 9-10 digit codes. Is it really the sensitive where u have to press the buttons perdectly at the same time?
Old 09-17-2012, 05:16 PM
bkun bkun is offline
Mein Auto: BMW 528xi - 2008
I have the same problem. Couldn't program the car remote. Didn't have the problem programming wifey's car.
2008 BMW 528xi space gray, Premium, Cold Weather Package.
Old 09-17-2012, 05:25 PM
Arch_Angel35 Arch_Angel35 is offline
Bimmer ****
Mein Auto: 2011 BMW 335D
You have to follow the directions in the manual exactly. Don't skip the learning steps even if you have an opener with a rolling code.
I was frustrated with mine until a neighbor came out and said told me not to skip the learning steps.
Old 09-17-2012, 05:37 PM
F1.tifosi's Avatar
Bimmer Craze
Well everything is tried, nothing working...
I am sure there is a glitch or some sort of knack...
Old 09-17-2012, 05:38 PM
bschmidt25 bschmidt25 is offline
Mein Auto: '07 530xi, '01 525iT
If you have a brand new opener like the Liftmaster MyQ (aka Security+ 2.0), it won't work with anything but the newest Homelink transmitters because it operates on a different frequency than the older openers. My father had this issue with his '09 335. After beating our heads against the wall with it for about 30 minutes, I did some research and found the following information: http://blog.gdcorp.com/2011/09/02/li...in-car-remote/
There is a repeater available to get Homelink to work again. We were able to get one through the manufacturer for only the shipping charges. YMMV.
Old 09-17-2012, 05:50 PM
Just FYI - Here's how I've always been able to program the Homelink successfully...
Hold buttons 1 and 3 for about 20-30 seconds to clear the existing codes. The light on the Homelink will remain solid for a while, then blink slowly. Once it starts blinking slowly, you can stop pressing the buttons. The codes should be cleared at this point. You can verify by pressing any of the buttons. They should all blink slowly.
To program, press and hold the Homelink button you want to program (it should be blinking slowly) and at the same time (without waiting) hold the remote for the opener close to the Homelink and press and hold the button on the opener remote. It should either stop flashing (become solid) or start flashing rapidly after about 5 seconds. A solid light means your opener doesn't have a rolling code. You are finished if that's the case. Try using it to make sure.
If you get the fast blink, your Homelink is programmed, but there's one more step you need to do. Press the learn button the garage door opener, then get back in your car within 30 seconds and press the appropriate button the Homelink transmitter. The lights on opener should turn off and on one time if it's successful. Test to make sure it works.
If the Homelink doesn't respond when you try and program one of the buttons, you may have one of the newer openers that use a different frequency. I believe the new ones are 900 some MHz while the older ones were 400 something. Hope this helps...
Old 09-17-2012, 05:54 PM
F1.tifosi's Avatar
Bimmer Craze
Thank you bschmidt.. I wil try your solution and keep You updated..
Old 09-17-2012, 06:01 PM
Rebound X3 Rebound X3 is offline
Mein Auto: 2010 528Xi
I had a problem programming mine when I followed the BMW manual. You also should check the manual for your opener, when I followed that, it worked. Good luck!
Old 09-17-2012, 06:04 PM
F1.tifosi's Avatar
Bimmer Craze
Sure rebound x3 will check your option as well...
Old 09-17-2012, 06:12 PM
The main thing is pressing the learn button on the garage door opener after you program the Homelink if you have an opener with a rolling code. Most people think they're done after they program the Homelink. The opener has to "learn" every remote you want to use.
Old 09-17-2012, 06:15 PM
C
Old 09-17-2012, 06:17 PM
Holly crap!!!! It worked!!!! That last step is the key. Took two tries but worked. Thanks guys
Old 09-17-2012, 06:36 PM
Glad it worked!
Old 09-17-2012, 07:15 PM
booyaazaa's Avatar
booyaazaa booyaazaa is online now
Mein Auto: '09 AW 535i
+1
My parents forgot this step when programming their new Merc one time.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs.
Old 09-18-2012, 12:10 PM
TallCanuck TallCanuck is offline
Mein Auto: 2008 535 XI Touring MT
+2
It took forever to figure it out but this last step was key.
TC
Originally Posted by booyaazaa View Post
+1
Old 09-22-2012, 09:17 AM
F1.tifosi's Avatar
Bimmer Craze
Omg, i have been trying this for days... bschmidt25 you are right, the last step is the key..
I just completed the steps successfully... thank you
Old 09-22-2012, 05:05 PM
Anytime! Glad to help
