X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
Implications of the new iPhone 5 and the new lightening dock
I think the new iPhone 5 Lightening dock connector is going to have some significant impact on interfacing to BMWs. Both older MULF and Combox iphone interface cars.
Just a bit history. Originally the iPhone/USB functionality was provided by MULF2. This was used for both CCC and CIC vehicles. Then BMW introduced a new interface with artwork ... single cable connection, etc .. and that introduced "combox" In any case, obviously it will have a impact on owners that are using the current cradles regardless of years. You won't be able to plug your new iPhone 5 in the cradle with the adapter apple is providing for backwards compatibility. But beyond that for cars that use the MULF, a Y cable was used to interface the car to the iphone: I would expect this to no longer work, since lightening is a digital only interface ... and BMW used the analog audio outputs from the 30 pin connector. So that isn't going to work. It might control the iPhone, but you're not going to get any analog audio out of the iphone that the BMW can use. I guess you could use a 3.5mm cable from the iPhone headphone out to the BMW Aux jack .. and keep the y-cable for control. A possible workaround. Combox cars would be ok, since it only uses the iPhone's digital interface .... however there is one exception. Plugin. That actually uses the analog audio out from the 30 pin ... but since that actually required the cradle (unless you did a 3rd party non cradle version) .. its a moot point. In any case ... definitely will cause a headache for non-combox cars !!! Progress I guess. ** EDIT ** Apple have confirmed that the adapter does support analog audio out, so this should no longer be a issue Last edited by apw2607; 09-14-2012 at 09:15 AM. |
Maybe the adapter Apple is making, takes care of these issues?
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
I think BMW frankly doesn't have to worry with the current e70, as its EOL so frankly they would just make an oem adapter available. With the Next gen, they've probably put that in development to accommodate, and most LCIs will take care of the rest of the F-based cars.
Btw would not purchase an iPhone till the next iteration, since it's lacking compared some of the features of the S3. In regards to the adapter, I'm guessing since most docks used the 30 pin to stream audio out, and the new adapter is suppose to Help accommodate the new dock to the old accessories, the current combox should be fine with the 5. However I'm guessing pretty soon, the per 5 devices are gonna be dropped from the next gen BMW combox, as their current no adapter to take the 30 pin to the new dock.
BMW and Mercedes Build Beta Products! Lexus build Release Candidate Products! Why does this matter? CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world! |
Digital to analog converter inside the adapter ... Possibly.
that's funny - I certainy didn't buy our BMWs based on their features compared to a competing model...
'06 M3 Silver/Gray '11 X5 35d Sparkling Bronze/Oyster '88 M3 Silver/Black, 47k Miles, Stock, Garage Queen... |
Just got confirmation, the 5 has no way of interfacing with current BMW tech that uses analog iPod out or video. Would require extensive reworking of the app, and interfaces. Bluetooth anyone?
What ideology do you use to purchase a BMW or any car or material possession? Interested to hear
BMW and Mercedes Build Beta Products! Lexus build Release Candidate Products! Why does this matter? CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world! Last edited by NoI4plz; 09-13-2012 at 08:13 PM. |
Ideology? You used the term "features". Is cost a feature? Reliability? Ownership experience? Etc... I'm not intereted in an S3 as it doesn't have the features which I value.
That should cover pre-Combox models that used the Y-cable. |
Newbie question, what is combox?
Combox is a interface/smart module which pretty much handles all ur phone to idrive connection, BMW apps, and whole lot other features.
Is that the optional box that goes in the console that you snap in your phone?
Edit: it's right rear trunk area
BMW and Mercedes Build Beta Products! Lexus build Release Candidate Products! Why does this matter? CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world! Last edited by NoI4plz; 09-14-2012 at 01:06 PM. |
Thank you for your responses. I just purchased a CPO 2011 and was wondering if ours has the combox?
However, it still seems silly to form a decisive position without even using/experiencing the product. Keep in mind that I am not objective regarding the iPhone 5 as I have other Apple products and, for multiple reasons, choose to stay in that product line.
Combox is located in the right rear trunk area.
Apple have now clarified :
The Lightning to 30-pin adapter supports analog audio output, USB audio, as well as syncing and charging, but does not support video output. Therefore it will work fine with current and older BMW ipod interfaces (both MULF and Combox). Since video output is not supported, this adapter will not work with Ipod Out. Therefore for all the folks that retrofitted Combox with iPod out, and didn't go for the cradle (there was a clever way of doing this through 3rd party vendors) ... you're be out of luck (for now at least). For cradle users ... don't worry, a new cradle will be on the way for the Iphone 5. Expect it in Summer 2013 ... knowing how BMW are. Quite frankly, BMW need to just drop the whole notion of cradle. It provides so little value, its not worth the effort. |
Combox control unit is the electronics and software that allows iDrive to work with external sources for music (and video). It supports three wired inputs. One via the USB interface, one via the cradle, and then the regular aux jack. On other vehicles it can support additional USB interfaces that may be located in the rear of the car. It also supports all the bluetooth functionality ... including telephone BT and audio BT streaming. It handles the cataloging of music files, album art, etc. Newer versions support the BMW apps platform and BMW live and BMW internet. Additionally, Combox can be purchased with telematics, for BMW assist services too. Last edited by apw2607; 09-14-2012 at 09:13 AM. |
The isheeple make idiots of themselves once again:
http://www.youtube.com/watch?feature...&v=rdIWKytq_q4 |
I'm confused one aspect. If analog audio is supported, but not video or iPod out, how will the apps platform work on the car?
I think BMW should try a modular architecture to the infotainment system. We have the performance products from BMW, they should also pioneer a tech products line.
What do I mean? 1) Make the navigation system a modular platform. Individual pieces of the system are simple to install and get working. I would love to not have to regret not ticking the navigation option, and have it installed later from BMW. 2) Remove the CRADLE and the BMW approved cabling Its better to invest in some altered NFC based system. No cables no hassle. Backup and power would offer a USB jack, that can handle a smartphones Integration. 3) Optimize APPs
#25
http://www.bmwblog.com/2012/07/10/bm...d-apps-coming/ |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
