Old 09-12-2012, 07:58 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Flickering / Pulsating Interior Lighting?
When stopped and idling and the main overhead and foot well lights are turned on, does anyone notice a flickering / pulsating of the interior lighting? The tachometer is as steady as can be and revving the engine a little does not change anything. I'm not entirely sure, but believe this is a new problem.
Old 09-12-2012, 11:34 PM
MMLLC MMLLC is offline
Mein Auto: 2009 BMW 750i
Sounds like a connection problem.
When it does it again, I'd try turning on and off things that pull from the battery; press the max AC button on off, radio, move your seat up down, etc.
See if that changes anything. If not, I'd say its a loose wiring/fuse.
...or your car is catching the Fisker syndrome and will soon go up in flames
Current Vehicles:
2009 750i fully loaded, Dinan S1, tint all around
2011 Maserati GT Conv.
2008 F250 King Ranch Diesel
Past Vehicles:
2008 M6 Conv
2008 S65 AMG
2009 Lexus LX570
2007 X5 4.8
2008 RR SC
2003 M3 Conv; totalled
Old 09-13-2012, 08:30 AM
Yes, I tried that when this occurred, along with revving the engine a little, but no change. The flickering is very subtle, but it's there. Hopefully a one-time occurrence that does not persist! Thanks.
Old 09-13-2012, 01:16 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
It could be a bad set of bulbs that are flickering and not actually an electrical issue.
Old 09-13-2012, 01:35 PM
Thanks, but they all pulsate together in sync. Hopefully it goes away...
Old 09-13-2012, 03:52 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
I have never noticed anything like this before, but will keep an eye out. Keep us posted if you come up with anything. My first response was to turn things off one by one, but it appears that is not the problem.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 09-13-2012, 04:04 PM
Yes, I too thought it was a matter of the system having a high load, but apparently not the case; I shall keep you posted. Thanks!
