E46 (1999 - 2006)
Old 09-12-2012, 08:46 PM
anton2718 anton2718 is offline
Mein Auto: 01 325i
m5 clutch on e46
does anyone know if an e39 m5 clutch and flywheel would fit a 2001 325i?
Old 09-13-2012, 05:44 AM
SPDSKTR SPDSKTR is offline
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
To answer your question... A popular combination for an aftermarket clutch and flywheel setup is the ///M5 clutch and UUC lightweight flywheel. They claim it's great for daily driving, but it's a lightweight flywheel that weighs 1/3 the weight of a stock flywheel (8 lbs.). Your car will rev fast, rev hard, and the clutch will probably grab something fierce. Another one I've seen tossed around is the Gripforce clutch and flywheel combo. I believe their flywheel weighs roughly 16 lbs., so it's not as difficult to drive, but it's still going to be completely different than what you have now.
Then again, if you just want an OEM flywheel with the ///M5 clutch, you should be fine. I believe the clutch will feel significantly heavier and grab much more firmly than what you have now, though.
Old 09-13-2012, 06:20 AM
Mein Auto: 01 325i
so long story short, it will fit, and it will be better, right?
and yes its oem, stock e39 m5 that it'll be taken out of
Old 09-13-2012, 06:34 AM
Mein Auto: 01 325i
also, does it matter that the m5 is a six speed and my e46 is a five speed?
Old 09-13-2012, 07:07 AM
Yes, it will work, but... why are you getting a used clutch?
Read this: http://forum.e46fanatics.com/showthread.php?t=221401 - It will prove informative.
Old 09-13-2012, 09:17 AM
Mein Auto: 01 325i
thats an e34 not an e39 though, im getting it because it doesn't have alot of miles on it and it $350 for the clutch and flywheel together
Old 09-13-2012, 09:45 AM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Let me tell you with my experience on my gripforce stage 2 clutch. It is stiff as ****. Probably one of the stiffest clutches I've ever driven even more than a Ferrari testarossa. But it does grip like a mfer.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 09-13-2012, 10:12 AM
Why not just a Stage 1?
Oh. Right. Because MalibuMafiaV.
Old 09-13-2012, 10:20 AM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
The E39 M5 has a V8, NOT an I6....everything is different. You would need a clutch from the previous generation E34 M5, which had an I6 engine....
Stay away from those 8-pound ultra-lightweight flywheels, there`s a good reason why they`re labeled "For Off-Road Use Only".
A Gripforce Stage II with the solid billet 16-lb. `wheel would be your best bet....the kit (clutch, flywheel, T/O bearing) can be had for around $500, a stellar deal.
The road goes ever onward....
(R.I.P. Jever)
Old 09-13-2012, 10:30 AM
Mein Auto: 01 325i
and where can i acquire one of these?
Old 09-13-2012, 10:36 AM
Fast Bob's Avatar
Keeping it surreal
Right here:
http://www.ebay.com/itm/F1-STAGE-2-C...orcev4exp=true
(R.I.P. Jever)
Old 09-13-2012, 10:46 AM
Fast Bob's Avatar
Keeping it surreal
He has to uphold his reputation as a stiff....
(R.I.P. Jever)
Old 09-13-2012, 10:53 AM
Mein Auto: 01 325i
why not get a stage 4 for $30 more then?
Old 09-13-2012, 10:56 AM
Mein Auto: 01 325i
if i get just that clutch, would it fit with my stock flywheel?
Old 09-13-2012, 11:01 AM
If I just told him to get an E39 clutch, I apologize. My brain registered what he typed as E34.
And 16 lbs. sure would be easier to drive than an 8 lb. flywheel, but it still seems like it would be a bit more challenging than the OEM 25-ish lbs. Am I wrong?
Old 09-13-2012, 11:02 AM
Because you don't have 800 WHP. A Stage 2, in my eyes, is pushing it (going off what Malibu says). A Stage 1 would make for a better daily driver.
Old 09-13-2012, 11:10 AM
Mein Auto: 01 325i
alright sweet, it is my daily driver, the reason i wanted get a flywheel is because id need one if i got an m5 clutch but otherwise i dont think i need one, unless this ebay clutch wont fit my stock flywheel
Old 09-13-2012, 11:27 AM
Fast Bob's Avatar
Keeping it surreal
No....the stock (dual-mass) `wheel only takes the self-adjusting clutch, a solid-billet `wheels requires a sprung-hub clutch, which is quite different.
Just get a Stage I setup and be happy....people say the Stage I feels just about identical to a stock unit.
(R.I.P. Jever)
Old 09-13-2012, 11:35 AM
TheMalibuMafia
SPD is correct. Stage 1 is great for daily driving. But I had to get a stage 2 in order to support the power and driving style of my bimmer. I knew a stage 1 might be ok but for how hard I drive the car it wouldn't hold up as well as the stage 2.
TheMalibuMafia.com
Old 09-13-2012, 11:37 AM
Mein Auto: 01 325i
thats exactly why i want at least a stage 2, i drive mine daily and pretty hard too
Old 09-13-2012, 11:38 AM
Mein Auto: 01 325i
can i get stage 2 clutch with my stock flywheel somewhere?
Old 09-13-2012, 11:49 AM
Does your car make 400 WHP? No? Get a Stage 1 at the most.
Read this for a bit of educational material: http://store.uucmotorwerks.com/share...3&Refresh=True
Originally Posted by UUC Motorwerks
To repeat the important point, do not buy more clutch than you need.
A simple organic disk will handle a wide variety of use - including street use, auto-x, and even true racing. In fact, SCCA ITS racing rules require a standard OE-spec organic disk. UUC has tested organic disks to reliably handle up to 475hp in long-term street use. M3s regularly run through several auto-x seasons without problems.
A kevlar disk is a good choice for a heavily-tracked or road-raced cars, especially with forced induction.
Carbon/ceramic should be left to high-power cars that see lots of drag racing, or are dedicated track/drag cars.
Sintered iron clutch disks are strictly for endurance racing.
You don't need to go buy the most expensive Stage 84 clutch out there just because you want one. Malibu's car is supercharged, meaning it puts down some significant power. He needs a clutch that's able to hold that much power when he's really romping down on the throttle. Your car, a 325i, doesn't need something like that. Your car will probably never see past 200 WHP (just being realistic), so there really isn't a need to get a Stage 3 or Stage 4 clutch.
Old 09-13-2012, 11:54 AM
TheMalibuMafia
The only reason I have a stage 2 though is because my car is supercharged. You don't need a stage 2 for a stock engine at all.
TheMalibuMafia.com
Old 09-13-2012, 11:56 AM
How old do you think OP is? 18? 19?
Old 09-13-2012, 12:07 PM
Fast Bob's Avatar
Keeping it surreal
NO it`s not possible (didn`t you read my answer about 5 posts back ?)
And, as mentioned, you don`t need anything beyond a Stage I for a 150 RWHP car....
(R.I.P. Jever)
