Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 09-12-2012, 09:05 PM
flash_n flash_n is offline
Mein Auto: 745Li
DIY - Vacuum Pump Seal Kit & Oil Pressure Switch
I recently noted some oil leaks and figured I'd start with the vacuum pump and oil pressure switch.
For this E65/E66 DIY you'll need:
- Oil pressure switch : 12617568480 : 10$
- Vacuum Pump Seal Kit : 11667545384 : 18$
- Hose clamp : 2$
- Vacuum Hose 3,5mmX1,8mmX3m : 10$
- Permatex Form-A-Gasket No. 2 : 10$
- Mobil 1 syntetic grease (or any other) : 10$
- Torque wrench capable of 10 - 20NM
- Torx sockets (male & female)
- 24mm deep hex socket for sensor
- 27mm deep hex socket to crank engine to align vac pump groove
Difficulty Level 1-10: 3
To have good access to the sensor I cleared out the area quite a bit. Its a suggestion.
Also let the engine cool down.
1) Remove engine accoustic cover
2) Remove air filter housing from MAF
3) Disconnect MAF sensor cable
4) Loosen clamp between MAF and engine intake, remove small hose and rotate MAF 90 degree up
5) Remove radiator fan (see TIS)
6) Remove vacuum pump (see TIS)
Note:
- you really have to remove the hoses from the bracket. Otherwise you can't get it out.
- the small hose attached to my vac pump was really brittle and I had to replace the line.
- get about 3m of hose, then you won't be short.
RECALL
- check if you have oil in the thick tube connected to the vacuum pump. I used a QTip for that. If you do have oil in the hose, the vacuum pump is defective and could damage your brake booster.
Now is a good time to replace the oil pressure sensor. (See TIS)
a) Release the plug connector
b) Unscrew the sensor
c) Put some (LITTLE) Permatex on the middle of the thread. I'd apply it with a QTip.
d) Torque to 13NM
e) Re-attach connector plug
7) Once the vacuum pump is out, you can take the cover off, clean the surfaces and replace the inner seal. Some joker had overtorqued one of the bolts, which I had to replace with a 6mm round head. Torque housing bolts to 12NM.
8) The outer seal is replaced last.
9) Reinstall the vac pump with the groove and drive aligned vertical. I put "some" grease on the drive to prevent flopping. Make sure the seal is in place and not being pinched anywhere.
10) Before you put the fasteners back in place, you can slightly rotate the vac pump 5-10 degrees. If you hear a light smacking sound, then its aligned.
11) Torque vacuum pump to cylinder head with 10NM.
12) Attach the hoses to the vacuum pump using a new hose clamp.
14) Put everything back together again.
Hope this is a help to someone.
Regards, flash-n
ID:	341633   Click image for larger version
ID:	341634   Click image for larger version
ID:	341635   Click image for larger version
ID:	341636   Click image for larger version
ID:	341638   Click image for larger version
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
Old 10-09-2012, 09:57 AM
theckj theckj is offline
Mein Auto: E65
Great write-up. I did this this past weekend. The tip on cranking the engine with a 27mm socket was super helpful.
On my 2006 E65 I didn't need to remove the radiator fan. Once I took out the passenger side filter box and the engine cover housings, MAF air intake, there was plenty of room for me to work. I used a 4 inch deep female torxx socket for the star bolts on the pump. This helped with the lower bolts.
One of the easier jobs I've done.
Old 01-09-2013, 04:29 AM
Mein Auto: 745Li
The seal kit is available at BMPDesign with the following PN 305162.
next up: P0492
Old 03-17-2013, 01:57 PM
tazman30338 tazman30338 is offline
Mein Auto: 745i
Great write ups. Thank you! I am need of some help as soon as possible. I will pay for some telephone or email support if necessary, as I need this car running by morning.
I just replaced my vacuum pump and the 2 seals on each of the 2 solenoids . I also read the TIS. The install seemed to go well, including cranking the engine shaft to vertically align drive. When I started the car. It ran very rough. Passenger side of bank was making missing/knocking noise. I re-installed the pump. Everything seemed to install easy and fine. When I start the card it runs very rough- knocking and missing noise.
Please help. Text, call or email. I am on EDT. It is currently 4:56 here.
Glenn
glenn.gandy@gmail.com
678-576-7287
Old 03-19-2013, 11:51 AM
Mein Auto: 745Li
Luckily we were able to trace the problem with the install of the solenoids.
We should open a separate thread on the resolution, in case s.o. else runs into the same issues.
next up: P0492
Old 04-01-2013, 08:49 AM
nyoung nyoung is offline
Mein Auto: 2005 545i
Vacumm pump seals question
Hello,
I'm about to take on this vacumm pump seal problem in the near future. I have an 05 545i. What solenoids are you guys referring to? Do the solenoids have to be removed with installing new gaskets in the vacuum pump? I appreciate this write up!
Old 04-01-2013, 04:42 PM
Mein Auto: 745Li
Hi, the solenoids and the vacuum pump are independent from one another. But you might as well do both jobs when you're in that area anyways.
Intended to do a separate writeup of the solenoids but didn't get around to it. There is some good info in the E65/66 forum.
next up: P0492
Old 04-02-2013, 09:12 AM
Thanks for the follow up. I appreciate the feed-back.
Old 05-19-2013, 03:11 PM
dgaletar dgaletar is offline
Mein Auto: 2007 750LI
Not so easy!!!
Hey guys. I'm working on my friends '07 750Li (E66), and the only thing left to do was the vac. pump. So I went to install it, and it wouldn't go in! I mean, it went in, but not tight. It had about 1/8 of an inch left to go, and it JUST WOULDN'T GO!!! I tried turning the engine over, and nothing. I then tried pulling it in with the bolts, it worked until I started it... and then the case broke.
So I went to a junk yard and got one off a wrecked car (same year and model). After a fight, it went in. But then, about 24 hours later, it started leaking a little, so I pulled it off and cleaned it up.
Then, as I was putting it back on, guess what happened... IT WOULD NOT GO IN THE 1/8" AGAIN!!!
Now I broke that one (after over an hour of a fight that I apparently lost).
WTF am I doing wrong here???
PLEASE HELP ME!!!
Old 05-19-2013, 03:31 PM
Mein Auto: 745Li
You are aligning the butterfly tab in the slot (step 9)? This would be the first question coming to my mind.
next up: P0492
Old 05-19-2013, 04:32 PM
Every time! At least i think that i am. If i wasn't, would that be the result? An 8th of an inch or less out??? I can't tell you how nuts this has made me!!!
(Image of how far it is still out)
Name:	2013-05-18 12.40.52.jpg
Old 05-20-2013, 10:56 AM
Mein Auto: 745Li
Yes that looks to me like the butterfly tab is not aligned.
If you manually rotate the crank bolt slowly, the slot will move along. Stop when its vertical.
Turn the tab on the vac pump until its vertical as well. Now put it on. It will be flush.
next up: P0492
Old 05-21-2013, 08:14 AM
You nailed it! It went right in. Thx!!!
Old 09-12-2013, 09:14 AM
Simpsonblake28 Simpsonblake28 is offline
Mein Auto: Bmw 745 li
oil leak. issue vaccum pump
can all of the work performed be done through the hood of the car? Or does it need to be on stands?
Old 09-12-2013, 09:46 AM
No. To do the tasks listed the car can be on the ground, & no tires need to come off.
Good luck!!!
Old 10-14-2013, 12:34 AM
bobbyggx bobbyggx is offline
Mein Auto: '11 BMW F10 535i
Hi guys!
I have a little problem after addressing the oil leakage from the vacuum pump. When the car idles and I hit the break pedal 2-3 times the break pedal becomes very hard and stays that way until I press the gas pedal and rev the engine. After revving the engine the break pedal becomes soft.
I've replaced all seals but a think I noticed is that before I disassembled the front part of the pump, the pump was rotating very hard! After I assembled it it was going without any problems, very easy. I'm not sure if what exactly the (9) means. When I was installing the pump on the car it was vertically and it snugged in perfectly.
I made an image after removing the cover. The photo is attached. The pump was assembled the same way.
P.S. After removing the pump from the car about 50ml of oil leaked on the ground. After installing the pump I didn't fill it with oil manually. The question is should I do it or the engine already filled it?
Thanks for your help!
Old 10-14-2013, 03:50 AM
I've disassembled the pump again. It is filled with oil but I have an other concern. When I removed the pump the first time before removing the front cover the pump was spinning hardly and it was going half a lap at a time. After the sealing change and assembling the pump is spinning freely, which I think might be the problem.
Old 10-15-2013, 12:46 PM
Mein Auto: 745Li
Did you check if any oil went in direction of the brake booster? If that is ok, I'd try another round of assy/disassy of the pump.
Be careful whatever you do. Not having full braking capability is a serious matter.
next up: P0492
Old 10-15-2013, 02:22 PM
Thanks for the reply!
I' e sorted things out!
The vacuum pump is as simple as it looks like! The problem in my case was the new inner sealing, it was a bit higher and because of it the pump couldn't make enough vacuum fast when the car is ideling. Now I'm using the old sealing and some thermal silicone.
Old 10-16-2013, 08:42 PM
whytry's Avatar
whytry whytry is offline
Mein Auto: '07 750Li, 68 Camaro
Might be a dumb question but where is this located? I can't totally tell from the pix... Passener side front of the motor, correct? If its leaking i would hear a vacuum leak, rt? The dealership said I needed to replace whatever that part is I'm speaking of... This sounds like the same thing... Also would/could this also cause a drop in mpg around town?
06 750i - Blk/Blk, Sport pkg, premium pkg, comfort access, ent pkg, convience pkg, 21's, sold
07 750LI - Blk/Blk, Sport, Premium, comfort access, rear DVD, convenience, 21's
68 Camaro - Procharged and injected LS2 in progress
Old 10-24-2013, 05:31 PM
bmishak bmishak is offline
Thrill ride
Mein Auto: 08 550i
I just got my 08 550i from California. The dealer had it for about six months. All the records for service are up to date. And it only has 32000 miles on it. But since it has been sitting I decided to go ahead and change the oil.
The dealership told me the I had some leaks from my vacuum pump and my oil pressure sensor. Could the breakdown be attributed to the car setting and the seals breaking down?
I am going to tackle it this weekend. I will let you guys know how it goes!!!!!
PS the dealership wanted $1000 dollars to change the vacuum pump and do the switch!!!!!!!!!
Old 01-08-2015, 03:18 PM
mgucci745 mgucci745 is offline
Teenage Car Enthusiast
Mein Auto: 2002 745i
What female torx size holds the pump in place? I think I have the right one but there's no way I can take it off with a screw driver. I need to use a wrench. Kinda confused :/ hope someone can help
This Car Im Driving Make U Feel Some Type Of Way
@V1SUALZ Los Angeles car v1sualz company coming soon!
F*** a lease, drive a e65
Old 01-09-2015, 07:03 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
E8 - female torx (mount bolts)
T25 - male torx (housing screws)
I used a slight layer of silicone as a secondary line of defense (longevity)
Just be careful around oil port & allow to dry for an hour or more after install
The early bird may get the worm, but the second mouse gets the cheese.
Old 07-15-2015, 12:11 PM
QuickSix QuickSix is offline
Mein Auto: 2005 645ci
Is a torque wrench absolutely necessary for these jobs? Have you all used one? I don't want to be a cheapskate but I really don't have any other use for one besides this that I can think of.
Old 07-17-2015, 12:51 PM
I don't use one unless I'm doing heads, rods/main bearings, etc. But after 30+ years, I have a good feel for bolt limits.
HTML code is Off
