Thanks, I guess there is always an exception to normal. To clarify, yes the e-box was well sealed and lid was on OK, but to describe better how it got water into it... i have to describe it better for those who haven't had the pleasure of experiencing this misfortune, it is mounted flush hard up against the firewall left side, in the rear of the engine compartment. You can't see where it is, until you remove the cabin filter housing just under the windscreen. Where the e-box touches the firewall, there is a hole tunnel through to the cabin for the wiring loom to enter the cabin area behind the glove compartment. That tunnel/hole "entry-way" normally is sealed around it's perimeter, but in this case the seal was parted, allowing the rain water (that normally drains down from the windscreen in a channel past that area) to enter the tunnel and e-box. So much water had entered there was a tide mark in the e-box up to the level of the hole. The Power Supply Module and loom connectors in the e-box had been submerged in water. Also the water could travel down the wiring loom into the cabin and fill the floor wells both sides, submerging the Computer Modules under the carpet. No wonder, (after being parked up long enough for this to happen) that the on-board-computers through so many fault warnings up on the I-Drive Screen when I first got back in to start it up, and didn't respond to engine start attempts. The car is still stripped apart, drying done, Modules being replaced, electrical connectors cleaned, ready for assembly and fault clearing etc..... lots of fun and money :-( I miss my black beauty
