Old 07-04-2009, 07:22 AM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
DIY: Hose for Altitude pressure sensor
My rubber hose for Altitude pressure sensor shows age and starts to crumble in my hand (#2 in link below):
http://www.realoem.com/bmw/showparts...=13&fg=15&hl=2
VACUUM HOSE BLACK PN: 11727545323 (Listed price $18!!!).
It is right in front of passenger's side strut tower.
I used standard vacuum tubing (or windshield washer tubing).
The job takes exactly 5 minutes including cutting tubing.
Use alittle oil to slide the new tubing through the grommet.
This is the shortest, quickest and easiest DIY of the E39 DIYs!!!
Skill level is 0 out 10 (10 is level of engine rebuilding!).
Actually it took me longer to finish my beer than doing this simple DIY!
Old 07-04-2009, 02:04 PM
BlackBMWs's Avatar
BlackBMWs BlackBMWs is offline
Check twice, fix once...
Mein Auto: 540it 533i 318ic 325i
Hi Cam! What was the symptom that caused you to check the hose? After replacement, did you notice any difference?
Happy 4th!
1999 540it - Jet Black/Sand Beige, style 5 rims, Zionsville Cooling kit
1984 533i - Schwarz/Schwarz, 17" style 65 reps
1997 318ti Sport - Schwartz II/Schwartz Anthratz, style 68 rims
1995 318ti Sport - Schwartz II/Schwartz Anthratz, style 27 rims
1994 325i Sedan - Bostongrau/Tan
1991 318ic - Schwarz/Anthratz Stoff
1985 635CSI - Schwartz\Sand - Sold
1984 318i - Champagne/Tan, Stock - Sold
BMWCCA# 160411
Old 07-04-2009, 02:08 PM
Rich,
No symptoms just looking around the engine bay and wondered what this thingy was.
Touched the hose and it crumpled in my hand!
Later I researched and found out this is an Altitude Sensor. I guess it measures mm Hg in reference to sea level to adjust fuel-to-air ratio.
Nothing important, I guess without the hose the Altitude Sensor still works but now at risk for debris entering it.
If you look carefully then the hose goes into a well-enclosed environment.
Happy 4th!!! Fireworks tonight yahoo!!!!
Old 05-04-2013, 10:49 PM
just looking around the engine bay and wondered what this thingy was!
I was doing some research for the altitude pressure sensor, and was looking for a picture - and was shocked to see a cn90 thread sans a photo!
Anyway, a bit of googling came up with this for the BMW E39 APS:
See also:
- How does the BMW E39 fuel trim behave at high elevation (1) (2) (3) & where is the BMW E39 altitude pressure sensor (APS) (1)
