BMW Coding and Programming
Discuss coding options and features on your BMW here. |
HUD Turn Signals
I am trying to activate the HUD turn signal in my 2013 535ix.
1. HU_NET / HUD_TURNSIGNAL = aktiv 2. KOMBI/BLINKER_HUD_ENABLE = aktiv There is no checkbox that shows up in the HUD settings. I have also found that the HUD_TURNSIGNAL is not in the 3000 HMI section as shown in the cheat sheet, but is in the 3001 EXBOX section on my car. Any ideas from the gurus?
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner |
When I enabled it; you had to click on "display options" first, then it gave you alist of itmees you can check, and uncheck; the "display Options" (maybe exact text is different) looks like a title for that menu, but when you select it, it brings up a bunch of things you can show or hide on the HUD, turn signals will appear in that list if you did everything right
The checkbox on the HUD display options is not coming up with the turn signal checkbox. I have checked the coding multiple times and it shows in the HU_NET and KOMBI that they are aktiv.
What are the CAFD File names for your HU_NBT and Kombi ECU's?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
ive set today the KOMBI/BLINKER_HUD_ENABLE to aktiv but not the second one.
id no access to internet while coding so i could only watch some pdf´s i got currently ive the checkbox for "Blinker" in settings but no Blinker in HUD while driving around i try to set the other option to aktiv too and will report |
kombi - cafd_00000069_009_000_042
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner Last edited by Ionic202; 09-13-2012 at 03:46 PM. |
Well, it could be different in 2013, but I highly doubt it. Just to make triple sure though, please check the following:
1) Code KOMBI / BLINKER_HUD_ENABLE = aktiv - This actually enables the feature. 2) Code HU_NBT / HUD_TURNSIGNAL = aktiv - This adds the iDrive Checkbox to toggle the feature on and off. 3) Go into iDrive HUD Settings, and enable checkbox for Hud Turn Signals as shown in attached picture.
2) yes 3) no check box on settings screen.
What options are shown on your HUD Settings Screen? Can you post a picture of it?
No Sorry - I'm a 2012 Nov15/2012 build...
Ok. We need someone else with the new HU_NBT to see what is going on.
Paging @falcongeek ...
I did some digging a while ago and couldn't find any additional settings that I though needed to be changed, but it is possible that I missed something. Adam |
It is the same as prior to coding.......
I have 47.1, is it possible that this is "fixed" in 47.4?
Maybe, but I think its an equal probability that if it will work it will work in 47.1 too and there is some other coding we need to find.
I am in 47.4.......
Well, that confirms that. It is likely that the HU_NBT firmware went unchanged from 47.1 to 47.4, so the ECU is the same. So, it is find some other missing coding, or hope a future firmware corrects the issue.
i cant get it work on my F30
1. HU_CIC / HUD_TURNSIGNAL = aktiv 2. KOMBI/BLINKER_HUD_ENABLE = aktiv Checkbox is there and choosen but no lights in HUD
Has anyone coded an F30 and got it to work?
Hey guys, I had the same issue with my 2013 535i as well. I figured it out eventually. You need to set one of the PIA options to aktiv (I don't remember the name). I will post it here once I get home.
Pia_Default_Tippblinken http://www.bimmerfest.com/forums/sho...182&highlight=
#25
Mine is F10 2013 with the new Nav. I'll keep you posted.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
