Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-13-2012, 06:05 PM
Wally91 Wally91 is offline
Mein Auto: Renault Clio mk3
Smile Considering to buy an E30
Hi everyone,
Basically I'm a car novice (know basic stuff about cars) and I'm thinking about buying an E30, possibly >87 model. I know older cars tend to have some problem after the other and being a student, I dont have much money to spend on repairs so I want this car to be a learning car where I can do things myself hence why I joined this site to gain some insight (and also I love BMWs). To me the E30 is one of the most beautiful BMWs made so I've set my eye on owning one. What I want to ask you all is advice on which engine size would be more economical, where i can get cheap car insurance (in the UK), what I need to look when buying an E30 (pros/cons). Thanks in advance!
Old 09-13-2012, 07:37 PM
Terrains's Avatar
Terrains Terrains is offline
Mein Auto: 1987 BMW 325e
http://forums.bimmerforums.com/forum...d.php?t=826530
Old 09-13-2012, 09:33 PM
BMWFatherFigure's Avatar
Old School
In the UK - rust! Cheapest is always the small engine 318i rather than 320 -323 - 325 - 328. Try for 320 if you need to do distance regularly. Go with manual if you have the licence. If you end up with M40 style engine change the timing belt straight away unless you are positive about age. The MOT should take care of worn suspension bushes etc. Get a w'shop manual. Beware accident damage.
Current:
Previous:
Old 09-14-2012, 12:49 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
I thought in England you just go out & steal whatever car you want ?
heh heh
Don't take life too seriously; no one gets out alive !
Old 09-14-2012, 05:10 PM
Thanks Terrains! I'll give that a read.
@BMW FF I'd prefer a manual ofcourse, and since i might be commuting in it (2hr drive a day) I think the 320 would be good.
Unfortunately Nick there arent any around my area
Old 09-14-2012, 09:38 PM
SturdyE30 SturdyE30 is offline
Mein Auto: BMW E30
its a great buy the only thing with E30's is that they need to be taken care of you will have a lot of minor problems so if you don't really have the money to put in which is not a lot considering that the parts are cheap you just have to do the labor on your own go for it!
Old 09-16-2012, 10:40 AM
Road Doggie Road Doggie is offline
FT BMWs PT Snowboarder
Mein Auto: 1986 325E
I am rehabing an E30 (1986 325 e) is repalcing the from steering componets i.e ball joints etc. within the reachnof the home mechanic to do efficently?
Old 09-16-2012, 10:47 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Yes, provided you have the correct tools and some know-how. You will need an alignment after replacing the parts, however. Best to do all the replaceable pieces at once. Bushings, sway bar drop links, lower control arms (which have the ball joints already attached) and tie rods (inner and outer).
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 09-16-2012, 02:20 PM
Old School
+1 hornhospital
Current:
Previous:
Old 09-17-2012, 01:58 AM
Nick323's Avatar
Nick's Toys
Febi sells the control arm with bushes & pins assembled at a price cheaper than the individual components
Old 03-15-2013, 02:24 PM
So I've found a 1990 E30 318is, considering to buy it. It has done 143k miles, failed it's MOT due to crank position sensor failure, however the owner has bought the CPS and fuel pump relays. With the sale comes new brake pads and discs, steering and fan belt. There is rust on drivers side rear quarter and arch and a few other small touches. The paint has seen better days, it's kinda peeling on some spots. For £750ish, Yay or nay?
