Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 09-14-2012, 07:40 AM
matts335 matts335 is offline
Mein Auto: 2009 335xdrive (E90)
ContiProContact SSR vs. Potentza RE960AS
Does anyone have any experience with these two tires? I'm talking specifically about the 225/45/17 size.
I had the conti's on my car orginally, but traded wheels after about 12,000 miles. The new wheels came with Turenzas which have now worn so unevenly they have to be replaced. I definitely liked the conti's better than the Turenzas. Had no issues with the conti's in terms of performance. Obviously they took the bumps hard, but weren't too bad.
I understand the "ultra high performance" RE960AS tires would perform better, but that's not my main concern. I'm equally, if not more concerned about the ride quality. These new 3G tires are supposed to ride more like a regular tire.
I've read conflicting reports. Some say the conti's are quieter and softer ride, while others say the opposite.
Has anyone gone from the conti's to the 3G potenzas?
Thanks for any help and input. I'll probably get the potenza's anyway just to try
Old 09-14-2012, 08:35 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
The Continental Pro Contact SSR is one of the softest riding run flat tires. You'll get better handling, wet and dry grip and faster steering response by going to the RE960 A/S RFT, but you may feel that the ride is a bit firmer.
Tires http://www.tirerack.com/a.jsp?a=AB2&...ires/index.jsp
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 09-14-2012, 11:37 AM
So you would disagree with you cohert's assessment?
http://www.northamericanmotoring.com...ition-rft.html
To be fair, he didn't mention ride quality specifically. He probably just meant overall, taking into account performance.
Thanks for the feedback.
Old 09-15-2012, 07:29 AM
Moderator
Nope, I would not disagree with his opinion. "The RE960 A/S Pole Position Runflat is in my opinion, the best runflat tire out on the market hands down. I tested it on the road, with and without air pressure. I also drove it on the track wet. It was OUTSTANDING". The only advantage of the Pro Contact over the 960 is a slightly softer ride.
Gary@Tirerack.com
Old 10-01-2012, 03:03 PM
pistolpuma's Avatar
pistolpuma pistolpuma is offline
Mein Auto: '08 328 E93 '12 X3 28i
Gary,
I'm about due to replace the RFT's on my '08 E93 with sport pkg. I have been looking closely at the RE960's mainly because of the longer life claims. I prefer RFT's and am willing to overlook adverse ride and cost in exchange for the safety. BUT I want something that lasts longer. The RE960's, by most reports, seem to have made improvements there. Are you aware of any new RFT products that may be coming out in the next 6 months or so that will offer extended wear characteristics?
I'll be switching over to the snows in 6 wks or so and will want them this spring. Thanks.
Old 10-02-2012, 07:28 AM
Moderator
Originally Posted by pistolpuma View Post
Gary,
You're on the right track. The longest wearing run flat tire available in the staggered 18" sport tire sizes bar none is the RE960 A/S Pole Position RFT. I see no information about plans of other companies to release any new tires in these sizes in the next six moths.
Gary@Tirerack.com
Old 10-02-2012, 09:19 AM
BruceOmega BruceOmega is offline
Mein Auto: 2008 535Xi, 2006 X3 (wife
Gary,
I hope the OP doesn't mind if I expand on this. I have a 2013 F30 xDrive Sportline on order with 225/45-18 tires and 18 x 8 wheels all around. I opted for performance summer tires and will be getting the increased top speed limiter.
If I want to switch to high performance all-seasons, would you recommend the RE960AS in the closest available size, 245/40-18? Their diameter is 25.7 while the OEM 225/45-18's are 25.9. If so, would you recommend I go with wider wheels, and would that fit on the F30?
If I was willing to forego run flats, what high performance all season tires would you recommend in the 225/45-18 OEM size?
Bruce
2013 335i xDrive, Mineral Grey, Sportline, Black/Red leather, Dynamic Handling, Sport AT, Performance Tires, Increased Top Speed, Premium Pkg, Cold Weather Pkg, HK audio
2011 X3 35i, Titanium Silver, Black Nevada, Fineline Wave Wood, Premium, Technology, Cold Weather, Dynamic Handling, Sport Activity, 19" wheels, Premium Hi-Fi, Sat Radio
2008 535Xi retired
Old 10-03-2012, 05:23 AM
Moderator
245/40R18 fits and works quite well on the 2013 335i and even fits on the factory 18X8 wheels. If you decide to use non run flat tires, I'd suggest the newer version of the tire, the RE970 A/S Pole Position.
Gary@Tirerack.com
Old 10-04-2012, 11:46 AM
Gary,
Thank you. Does it make any difference that my car is an xDrive?
My 8" wide factory wheels are the minimum recommended width according to Bridgestone. Are there any issues with using minimum width wheels / any impact on handling?
Bruce
2008 535Xi retired
Old 10-05-2012, 05:46 AM
Moderator
Originally Posted by BruceOmega View Post
Gary,
Bruce
As long as you're in the recommended rim width range, the tires will function correctly. No issues with using them on an Xdrive.
Gary@Tirerack.com
Old 11-06-2012, 06:16 AM
ktimov1 ktimov1 is offline
Mein Auto: 2006 328i
I currently have the ContiProContact OEM RFT and will need to replace them soon. I was considering the RE970AS Pole Position. Since this is a non-rft, would you say that the ride on these would be more comfortable than the Conti's, lower noise as well?
What do you think?
Old 11-06-2012, 07:58 AM
Moderator
What do you think?
You may feel a very slight improvement in ride with the non run flat Re970A/S compared to the Pro Contact SSR. Noise levels should be pretty similar between the two.
Gary@Tirerack.com
Old 11-25-2012, 08:38 AM
360fg 360fg is offline
Mein Auto: 2010 328i xdrive
Any chance you made the switch to the RE960AS tires?
I'm looking for some real world comparisons on on the difference between the Conti's and those. To me the Conti's are not a viable option if you live in an area with rough roads, at least not for me. Not really wanting to abandon the RFT's as my 328 doesn't have enough storage space as it is due to the lack of a fold down rear seat.
