Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 09-14-2012, 01:38 PM
Gregroche04 Gregroche04 is offline
Mein Auto: BMW 630i
Dension DIY installation has lead to PDC acting weird
Hi guys
I would really appreciate any advice on this, also I have just joined the forum and I hope I am in the correct section
I own a BMW 630i 2005 with the M-ASK single slot idrive 6.5 and with a CDC
I remove the CDC to install the Dension 500sBT system
I had a play around with the Dip switch settings on the device in order to make it work with my car
However after doing so, I noticed when I put the car into reverse that the PDC, parking distance control is acting irractically and the rear sensor is a continuos beep.
I don't know if the dension installation has something to do with it or it is just a coincendence and that one of the sensor has failed.
I feel pretty dishearted as I just got my car and really would love to know what the solution is to
1. Fix the PDC
2. Install the dension
3. Can it be fixed ? And would a software update help?
I really appreciate any advice given and I would be very humbled.
Greg
Old 09-15-2012, 12:07 AM
Yorgi's Avatar
Yorgi Yorgi is offline
I would try re-posting in the main 6 series section located here. This is the DIY (do it yourself) section and it does not get many views.
A few people have installed the Dension so they might have some advice.
The PDC control unit is a separate module so I don't think that is the issue. Maybe try pulling the connections to the sensors and re-connecting them one at a time to see if you can identify a bad sensor.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 09-15-2012, 01:40 AM
Mein Auto: BMW 630i
Thanks yorgi , I'll do that
