Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 09-14-2012, 05:09 PM
beemer1804 beemer1804 is online now
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
Rough idle
My 95 E38 idles rough when under 1500rpm, do anybody know why its like that? Any answers or suggestions are welcomed bmw bretheran.
War Machine
Old 09-23-2012, 03:14 PM
BMWFatherFigure's Avatar
Old School
Looooooooong list. Vacuum leaks, fuel pressure, TPS, Air Mass device, Fuel filter, Spark plug(s), Coil Packs; CPS; Throttle Body settings; VANOS problems; What Codes are being displayed/stored?; Blocked exhaust; Blocked Air Filter; Fuel pump; Loose wires on the EMC loom - That should do as a start
Current:
Previous:
Old 09-23-2012, 03:23 PM
WAR MACHINE
Mein Auto: 95 740IL
Only codes displayed were o2 sensor then a few weeks later it said lambda, i checked for air leaks and nothing, i always knew that my fuel filter was bad, i was actualy gonna change that already, and of course my o2's. Hopefully something changes.
War Machine
Old 09-23-2012, 03:30 PM
WAR MACHINE
Mein Auto: 95 740IL
How do i check the vanos? And can my fuel filter cause war machine to shake, im guessing it effects my fuel pressure?
War Machine
Old 09-27-2012, 05:55 AM
bluebee's Avatar
bluebee bluebee is online now
Seek to understand,^Value
Originally Posted by BMWFatherFigure View Post
Looooooooong list
Believe it or not, over a period of a few years, I tried to compile the COMPLETE list of what SOLVED rough idle misfires over here in the E39 bestlinks (all of which should apply equally well to the E38):
- How to diagnose a BMW E39 engine misfire (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 09-27-2012, 05:58 AM
bluebee's Avatar
BTW, this tool (or an equivalent) is indispensable for troubleshooting rough idle misfires:
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Old 09-27-2012, 07:50 AM
WAR MACHINE
Mein Auto: 95 740IL
I thought 95 740il doesnt have vanos?
War Machine
HTML code is Off
