E30 (1982 - 1993)
Old 09-15-2012, 05:11 PM
Papa_ Papa_ is offline
Mein Auto: BMW E30
Reverse light problem!
Hey Bimmerfest! New to the BMW world and first post on Bimmerfest
Ok I have a problem. Currently in the process of getting my car ready for inspection. The last thing on my list to fix is my reverse lights.
Now I've searched every possible solution to this and still can't seem to fix it.
I've tried...I've checked the #10 fuse, checked for broken wires, checked for power in the wires, replaced my reverse switch everything!
Now with the reverse switch out of the transmission but still connected to the wires it works flawlessly...I manually press the switch and the reverse lights switch on and off.
It's as if nothing in the transmission is making contact with the switch.
Anybody have any ideas? I am desperate!
Old 09-16-2012, 12:27 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Is this a manual or automatic transmission?
Either way it sounds like some internal actuating lever has broken off.
You could try to mount a simple press-button switch somewhere on top of the transmission that gets pressed in by the gear lever moving into reverse....easier than removing and opening up a transmission.
Try posting this problem on the UK site www.e30zone.net
They have lots of experts there as regards the European/ Aus/ SA models are concerned
Old 09-16-2012, 03:22 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Is the car auto? If so, manual convert it and problem solved
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 09-16-2012, 06:11 AM
BMWFatherFigure's Avatar
Old School
Which gearbox - they used lots.
Current:
E38 Parts Car
Previous:
Old 10-13-2012, 07:24 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is online now
Mein Auto: 1989 E30; 2000 E38; GS350
It must be a stick since he said with the switch removed from the transmission he can push it and it works. The automatics reverse switch is in the gear selector.
Big Boyz with Bad Toyz
Big Boyz with Bad Toyz.
