E34 (1989 - 1995)
Old 09-13-2012, 01:07 PM
KevinGB KevinGB is offline
Mein Auto: '95 525i
Angry e34 won't start
Hey Folks,
Gotta a problem I can't find. '95 - 525i won't start. Did some simple cooling system repairs. When done, will not start.
Turns over fine. Fuel pump relay is good. Fuel filter is new. Fuel pump is recent and bench tests fine.
Starting fluid into intake, backfires ugly.
Crank sensor???
Again, all was fine before minor cooling system repairs (R&R rad. surge tank). Interestingly, low coolant level light is on. Was fine.
Thoughts? Comments?
Thanks,
Kevin
Old 09-13-2012, 05:03 PM
gfsys530isrcute gfsys530isrcute is offline
Mein Auto: 1995 BMW 530i
Why and what did you repair in the coolant system?
Old 09-13-2012, 05:04 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Welcome. I would suspect a bad crankshaft position sensor. Make sure to check the resistance before you buy a new one. It should read 540 ohms, +/- 10%.
Also, get a hold of a Bentley manual. You can purchase a hard copy or download a PDF copy. It is one of the best repair resources out there.
Again, welcome to the Fest.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-13-2012, 05:21 PM
BMWFatherFigure's Avatar
Old School
Backfire could be plug leads crossed or similar.
Current:
E38 Parts Car
Previous:
Old 09-13-2012, 06:42 PM
Big-t34 Big-t34 is offline
Mein Auto: E34 525i 95'
Cps
Old 09-13-2012, 07:08 PM
BMR_LVR's Avatar
Humble E34 lover
He has the M50 which has coil over plugs with no plug wires.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-13-2012, 07:15 PM
BMR_LVR's Avatar
Humble E34 lover
As usual, I forgot to mention one very important step .... do the stomp testl. It is detailed here:
http://www.bimmerfest.com/forums/sho...65#post5936965
GL
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-13-2012, 07:33 PM
Mein Auto: '95 525i
E34 won't start
Thanks. I'll jump back into it tomorrow morning. More to come.
Kevin
Old 09-13-2012, 08:36 PM
Mein Auto: 1989 525i M20B25
All else fails...Begin:
THE DEFINITIVE "NO START" trouble-shoot instructions - Bimmerforums - The Ultimate BMW Forum
Old 09-13-2012, 09:22 PM
Old School
OK - wires on wrong coil packs.
Current:
E38 Parts Car
Previous:
Old 09-17-2012, 10:33 AM
Mein Auto: '95 525i
Thanks to all replys. Still fighting this thing as time permits. Good thing wifey's car is working fine.
Stomp test, no codes.
CPS at plug at #1 & #2 reads low ohms,(<400). Ordered one, will R&R tomorrow. What a b---- finding/getting to the plug. Crankshaft sensor easy to find after pulling lower rad. hose (drain cooling etc).
More to come. Car has been flawless til now, ~200K mi. Want to continue running the wheels square because drivability etc is so good.
Kevin
Old 09-17-2012, 11:29 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
sounds to me more like intake leak for idel control or sensor plug crossed. could be flooded. let it dry out do not touch the gas petal when starting car.
Old 09-18-2012, 01:48 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
not really possible on the M50. its a complete harness, they aren't individual wires. you would know instantly if youd screwed that up. and they don't swap themselves anyway
E30 above Sold
Last updated 2nd January 2014
Old 09-18-2012, 11:47 AM
Mein Auto: '95 525i
Thumbs up E34 won't start
Hey there All,
Thanks for all posts and thoughts.
No start problem turned out to be the CPS. $100. Changed, runs fine. Have wounds on my 5 octave hand and arms that will go away in a week-ish. Yes, a PITA+. Still better than paying a dealer $500 or whatever and a tow when I'm not working steady.
If anyone needs a how-to on a '95 I'll be glad to help.
Best to All,
Kevin
Old 09-18-2012, 04:24 PM
Mein Auto: '95 525i
Thumbs up e34 won't atart
Tip top. All is good after changing the CPS, though challenging. Thanks to all who offered advice.
K
Old 09-18-2012, 08:38 PM
BMR_LVR's Avatar
Humble E34 lover
Great news
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
