The X5 SAV Forum
Old 09-21-2012, 12:27 AM
Jraww Jraww is offline
Mein Auto: 2002 BMW X5
Oil leaking
I did my oil change 2 months ago and i drove 4000 miles already and the check engine oil light came on. So i check it and the oil is low, so i'm wondering if my oil is leaking cause i haven't seen oil spots on my driveway
Sent from my MB855 using Bimmer App
Old 09-21-2012, 07:30 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Typical problem with BMW, crank-case ventilator valve is clogged or torn, reverse pressure on crank so engine burns oil faster than normal. Short trips and extended oil change contribute to the problem, as well as BMW engine is running very hot.
Old 09-21-2012, 09:02 AM
How can i fix this problem?
Old 09-21-2012, 12:19 PM
petener999's Avatar
petener999 petener999 is offline
Mein Auto: 750i, x5 4.6is, E46 M3
Engine 6 or 8?
Old 09-21-2012, 05:36 PM
Is a V6
Old 09-22-2012, 03:49 AM
BMWFatherFigure's Avatar
Old School
Jraww: Locate the damaged components. Buy them. Fit them.
Current:
E38 Parts Car
Previous:
Old 09-22-2012, 10:07 AM
motordavid's Avatar
motordavid motordavid is offline
RetiredBum
Mein Auto: '01 X5 3.0 '02VetteVert
I did my oil change 2 months ago and i drove 4000 miles already and the check engine oil light came on. So i check it and the oil is low, so i'm wondering if my oil is leaking cause i haven't seen oil spots on my driveway ...
Could be any of the items mentioned by other posters, or it could be as simple as 'normal oil consumption'.
BMW's 'standard' for E53 X5s is pretty broad/vague...
If you 'used' a couple of quarts in 4k miles, BMW would suggest that that is 'normal', 'within consumption specs', fwiw.
Where you drive is a fairly temperate climate, so I sort of doubt the CCV situ is the main problem, imo, though the CCV system can become clogged over time, in these cars, regardless of climate.
And, that oil light comes on at ~1 1/2 to 2 quarts low, which again, is not unheard of consumption in older E53s.
GL, mD
Ol'Uncle Motor
'01 X5 3.0 Sport, 5 Spd Manual, etc.
'02 VetteVert 6 Spd, Z51 susp.
'10 Hyundai Tucson for the CEO, & 3 Assorted M'Cycles.
BMW CCA mem. Tarheel Chapter
My Flickr...Scenes,Cars & Road Trip Pics:
http://www.flickr.com/photos/45275375@N00/
Old 10-02-2012, 07:12 AM
RED LION SOUND RED LION SOUND is offline
Mein Auto: 2006 BMW X5 4.4I
I have an 2006 bmw x5 and sometimes it gives off smoke,not at start up when vehicle is on and it sits for a while the smoke comes out the exhust and then when driving off it blows it out and then it stops
Old 10-02-2012, 09:08 AM
alex1989 alex1989 is offline
Mein Auto: 740 il
most of the time its oil filter housing gasket . its rubber and dry out all the time,. 2 hours with the work
You need to make sure it's the CCV first, some BMW shops (dealer or indy) use manometer to test. I assume you have no compression problem on your engine, thi sone will show as blue smoke out of tail pipe for sure (and less common unless you beat up on your car).
You can search for "CCV" here or Google it, many people gone through that burning oil problems and almost always it's clogged or torn diagphram of CCV.
