windshield wiper washers - Bimmerfest - BMW Forums
Old 09-17-2012, 06:37 PM
rx3 rx3 is offline
Mein Auto: Audi S4, Noble M12
My windshield wiper wiper reservoir was leaking at the location where the pipe mates to the pump. What a cheap set up. I fixed that, but now the pump is not working. I've checked fuses in the glove box and they are good. In checking the terminals at the pump, I see no voltage on my meter when the wiper stalk is pulled. Is there a hidden fuse somewhere? Thanks.
Old 09-17-2012, 08:07 PM
x3brian x3brian is online now
Mein Auto: X3
You might need a new pump. I just recently replaced mine with an aftermarket Uro one for $4.25 from ecstuning.com.
Old 09-17-2012, 08:32 PM
Mein Auto: 2004 X3 2.5i
Originally Posted by rx3 View Post
.... In checking the terminals at the pump, I see no voltage on my meter when the wiper stalk is pulled.
Were you separately checking both front and rear washers?
Were you dependent on someone else pushing the stalk to the right detent?
I can't see how the power would not be getting from the fuse panel to there.
A faulty switch on the column maybe, but as Brian suggests, the most likely situation is a failing pump that first started leaking, and then died when you had to apply pressure on the pipe connection.
Makes sense to just renew both pumps while you are at it (different part nos. I think) and be fairly confident that will be both a fix and proactive maintenance.
Old 09-18-2012, 06:32 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
It would be nice if you told us the year and model, you would get a lot more help that way.Its probably the pump. Both pumps have the same part # Go to amazon, OEM pump $10.95 shipping included,just make sure you order the pump with the right terminals, flat or round. One of the easy est fixes on the X3. Do a search . Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 09-25-2012, 03:07 PM
O7X3 O7X3 is offline
Mein Auto: 2007 X3
Question
I need a pic of a fuse diagram. Any help??
Thanks I'm having the same issue and would like to check the fuses before I buy two new pumps
2007 BMW X3
Old 09-26-2012, 06:03 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
Mine leaked and it was a bad pump. See this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=647329
Old 09-26-2012, 06:53 AM
Mein Auto: 2007 X3
I'm asking the same questions in the thread that you linked me to.
I even asked you in the other thread.
2007 BMW X3
Old 09-26-2012, 09:15 AM
Fuse Chart:
http://www.trapdoor.demon.co.uk/bmwx...use%20card.PDF
(Not sure if things changed a bit between 2004 -2006 and 2007 -2010)
Old 09-26-2012, 10:32 AM
Mein Auto: 2007 X3
Originally Posted by Supercourse View Post
Fuse Chart:
For some reason it says it cant find that page I swear this damn chart is like bigfoot!
Ive only heard about it
see if you can get me another link.
THANK YOU
2007 BMW X3
Old 09-26-2012, 11:02 AM
legalfee's Avatar
THANK YOU
Fuses 49, 52, 59
Old 09-26-2012, 11:39 AM
Mein Auto: 2007 X3
Fuses 49, 52, 59
Thank you, They should b the same for the 07 correct?
2007 BMW X3
Old 09-26-2012, 02:34 PM
usaret usaret is offline
Mein Auto: A Gamma Goat
Here's a scan of the chart from my 2009.
Name:	2009 Fuses.jpg
Old 09-26-2012, 03:31 PM
Mein Auto: 2007 X3
THANK YOU
Let me know if anyone thinks if there would be a difference between the 07 and the 09
2007 BMW X3
Old 10-07-2012, 04:29 PM
rx3 rx3 is offline
Well, I finally got me, the car and the pumps in the same location. I ordered 2 of the aftermarket ECS pumps ref'd above since they were so cheap. I checked both pumps by using a jumper wire from the battery. One was bad, so I changed it and kept the original for the other.
The aftermarket pump that I got has connecters that were different, so I had to make a set of connector wires. It works, but pressure is really low. Is there a way to adjust pressure?
thanks. This is for a 07 X3. Is that good enough Vern? BTW, nice pic in your post.
Rob
Old 10-08-2012, 06:01 AM
Mein Auto: 2007 X3
Rob
I ordered some off ebay and they work great. Are you asking me about adjusting pressure?
If so im not sure, is it the old one?? if so it is probably just weak. I paid $14 for two brand new ones and they work great, it specified on ebay if they were the tabs or the pins. So you can order the correct ones for your vehicle.
2007 BMW X3
