Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 09-19-2012, 03:30 AM
Kathy Doyle Kathy Doyle is offline
Mein Auto: 525i
Sensors
Hi i just recently noticed i have sensors does anyone know if a sensor on a 525i can make it sputter and lose power?Where and how to check them?
Old 09-19-2012, 07:09 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
You have several sensors that can cause different problems . Are you getting a check engine light?
Old 09-19-2012, 07:02 PM
Mein Auto: 525i
Yes sir i am and im so confused as to what to do from here the car is sucking air noises revving up and down on its own to the point it sounds like its choking out and theres no power when you rev to shift spitting and sputerring
Old 09-20-2012, 06:50 AM
Past Sponsor
Mein Auto: Many
Are you sure that there isn't an air leak. If something is allowing air to enter after the air flow sensor your car could behave in this manner. Are you getting a check engine light ? A code set by the computer will lead you in the right direction.
