Old 09-18-2012, 01:30 PM
Sammyboy112 Sammyboy112 is offline
Mein Auto: bmw 325xi
Cylinder Sleeve
Hello i have a cylinder 5 misfire in my car took it to the dealer they said it has some metal in the 5th cylinder so i need a new engine i was wondering if i could simply put a cylinder sleeve in the cylinder instead and obviously get wat ever is in there out.I have a 2006 325 xi also were can i buy a sleeve.
Old 09-18-2012, 02:24 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
.....what metal?
Just remove the head to expose the cyl.
If you don't know where to obtain a sleeve you're in no way prepared to replace it. Try a machine shop specializing in this sort of work.
Old 09-18-2012, 02:30 PM
33beto 33beto is offline
Send a message via AIM to 33beto Send a message via Yahoo to 33beto
Mein Auto: 2008 E90 328i / GM 6L45E
Seriously? and you believe this guys? then, dont bother getting a second opinion. just dump all that cash in it then.
(GONE!) Magnaflow Cat-Back - 18 Style 125 Rims - Black sport grills (GONE!) R.I.P. 10/13/12
Old 09-18-2012, 02:32 PM
CYylinder sleeve
they said it they dont know what metal possibly piston ring or spark plug idk how it got in there but im wondering if putting in the sleeve would solve my problem and im not going to put the sleeve in myself i just want to buy it so i can have someone do it for me.
Old 09-18-2012, 02:56 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Metal shavings/fragments in your engine is not the problem, it's a symptom. You need to identify and correct the cause or you solve nothing.
A single cylinder sleeve costs around $30-50.00. Even if you could order the correct part--which you can't, for a multitude of reasons--what do you hope to accomplish, except tick off the guy rebuilding your engine by nickle-and-dimeing the job? The labor and additional parts to rebuild the engine could easily surpass 100 times the cost of the sleeve.
The dealer said you need a new engine because it's more cost-efficient for a dealership to replace whole assemblies than to dismantle and rebuild them. They identify the smallest unit that can be replaced, not repaired, to correct your problem. In your case, that's an engine block plus whatever else failed and destroyed it--therefore, new engine.
Take your car to a BMW/European car engine rebuilder (hint: Google; yellow pages) and get a quote, then decide whether you're buying a new car.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 09-18-2012, 07:02 PM
cylinder sleeve
so are u suggesting to get a cylinder sleeve cuz thts wat i trying to do to avoid getting a new engine
Old 09-18-2012, 07:38 PM
Zeichen311's Avatar
I think what I suggested was perfectly clear: Take your car to a shop that specializes in rebuilding European-car engines and talk to them about your options.
You cannot just buy a sleeve and have someone install it. For starters, that is a huge, exacting and difficult job, like I already said. Worse, you haven't the faintest idea whether that is really all that needs to be done. None of us do, either. This is one of those situations where you can't really know what parts you need until you tear into the thing and assess the damage.
Talk to a pro. And bring your wallet.
Old 09-18-2012, 11:24 PM
First things first!
Boroscope that Jose t'see what's there. Prob a spark plug piece - hope it ain't injector or [worse] a piece of valve. Extract if can do.
Photograph; post here.
Old 09-19-2012, 02:51 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
I tend to doubt that installing a cylinder sleeve is going to be a realistic solution. The smallest unit that BMW sells is a complete block with pistons. The dealer basically wants to swap out a short or long block so they are not on the hook for any engine issues down the road.
Old 09-19-2012, 05:36 AM
Zeichen311's Avatar
Falls under "talk to a pro"--based on posts so far, d'ya really think OP knows his way around the business end of a borescope?
(anE934fun, I'm inclined to agree but figure it's at least worth asking an indie. I wonder if certain BMW blocks can be relined at all--thinking here of the Mg-Al block in the N52.)
Old 09-19-2012, 06:25 AM
Originally Posted by ane934fun View Post
i tend to doubt that installing a cylinder sleeve is going to be a realistic solution. The smallest unit that bmw sells is a complete block with pistons. The dealer basically wants to swap out a short or long block so they are not on the hook for any engine issues down the road.
Name:  Thumb up 01 [60].jpg
Old 09-19-2012, 06:32 AM
Falls under "talk to a pro"--based on posts so far, d'ya really think OP knows his way around the business end of a borescope?)
Instructions to OP:
Eyepiece end does NOT go into the cylinder!
Other end goes through spark plug hole.
Good luck! Post pics here!
Old 09-19-2012, 06:36 AM
Originally Posted by anE934fun View Post
I tend to doubt that installing a cylinder sleeve is going to be a realistic solution..
Hard to say w/o data.
However, that sleeve isn't going to be easy to source. BMW, like some others, modifies the piston surface of the sleeve for performance. "Red's Machine Shop" can't dup.
Old 09-19-2012, 10:37 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
The Block is magnesium aluminum.
The Block is magnesium aluminum I don't know if that can be re sleeved if then its
a total motor teardown.
Old 09-19-2012, 10:50 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
i dont think you'll be able to add a sleeve to the N52-- its an aluminum block with a ceramic coating on the cylinder bores. will be much cheaper to replace the engine with one out of a junked car.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 09-19-2012, 11:57 AM
Joe in Dublin Joe in Dublin is offline
Mein Auto: 335ic
U need to find out what was in the cylinder chamber and is there damage to the cylinder wall. If so, short block for u. I dought u can re sleeve these motors. I watched a movie about how the blocks are made. The sleeve looked to be a added , fused part of the mag block.
