Old 09-19-2012, 09:25 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
Power Trunk not working - Have to use key
Guys, I did SEARCH and came up with something. I should first check the wires for chafing and breaking around the hinges. And obvoiusly check the fuses. But do the actuators go bad a lot of the times? I found Ebay has tons of used actuactors for about $50. Should I go that route once I've narrowed it down more.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 09-20-2012, 04:08 AM
Fudman's Avatar
Fudman Fudman is offline
Yes the actuators go bad. I am in the process of replacing my door actuator. Negative on buying a used actuator, especially from FleaBay, unless you enjoy replacing actuators. You will have NO idea regarding the user life of a used component. And you can get a NEW VDO actuator from Pelican for $46 and $40 from BMA. Get a filter or two and you have free shipping.
Old 09-20-2012, 04:58 AM
^Bingo. I didn't do a furious search for the part #, but I threw this out b/c it's on the horizon of annoying problems the car has. Tomorrow evening I get my new BMW key Hopefully that fixes my keyless entry issue. both original keys I have are dead, dealer tested them. Back to the trunk deal... I'm going to check the wiring and fuses. I know when I press the button inside by thedrivers foot I hear something in the dash, like maybe a relay. So I'm betting it's wires or a actuator.
Old 09-20-2012, 07:48 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
Make sure the trunk lock doesn't turn to the "Valet" position. It happened to me before. The button inside and on the keyfob couldn't open the trunk, only manually with the key in the trunk lock.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 09-20-2012, 07:58 AM
^where is the valet switch? I think my 335i has one but cant' remember.
Old 09-20-2012, 08:26 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Everything you need to know about keys and key settings (including valet) has been posted by QSilver7 so do a specific search on his name.
Or ... type /valet F3 in the bestlinks ... and it will come up with good references:
For example:
- A description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys & settings (1) (2)
As for the trunk wiring loom and/or actuator, I just typed /trunk F3 and found this which may help you:
- How to repair your frayed trunk wiring loom (1) & an easy fix for your trunk latch (1) & a trunk lock actuator DIY (1) & how to replace your trunk shock absorber struts (1) or your E39 touring tailgate damper (1) & how to repair a broken trunk boot lock spring (1) & proper identification & location of relays in the trunk compartment & location of the fuel pump relay K96 (1) & how to open the hood (1) or boot manually when you have a dead 12v car battery (1) (2) & how to unlock the older E39 if the key is locked inside the trunk (1) (2)
Old 09-20-2012, 10:43 AM
It says in the owner manual. There is no switch. The key slot should be in vertical position for the buttons to open the trunk.
Old 09-20-2012, 10:51 AM
Thank you, as my car did not come with a owners manual. Looking on ebay for one... My cylinder opening is in the vertical position. So it's the wires, fuse or actuator. dam. never an easy fix. My 335i has a small blk hidden switch in the glove box for the trunk deal. Oh well. I'll figure out what's wrong with it. I got the direction I needed.
Old 09-20-2012, 10:58 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Stuff deleted
Download your owner's manual from here. Don't waste your $$ on fle-bay.
Cheers
Old 09-20-2012, 11:47 AM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
There are a few things that can cause the remote trunk release to fail. Trunk key turned to manual lock position, Broken wire in the "snorkel" going to the release, blown fuse, bad actuator, or just a broken spring. Do you hear anything when you try to open it remotely? If you do it's just a broken spring in the release mechanism that can easily be replaced. If not continue checking the other possibilities.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 09-20-2012, 06:34 PM
breiefley pulled the snorkel conduit out of the trunk and found one wire cut real bad, not broke, but sheeting was cut and spread 1/8". Will do more invest this weekend. I don't hear anything back there.
Old 01-07-2015, 02:13 PM
Allen Nugent Allen Nugent is offline
Mein Auto: E39 540i
Hi FLE39
Did you get this fixed?
I have the same problem, and I've found conflicting advice on whether or not the E39 even has a relay (some say the GM5 module drives the trunk release).
Old 01-07-2015, 05:27 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Any noise from the actuator when pressing the trunk release button? Have you skinned back the gaiter between the trunk lid and body, and looked for broken wires?
